Question about Motorola Radio Communications
How motorola gm300 work
How motorola gm300 vhf set work?
which type of antenna we will use to install this?
what is the diffrence in gm300 and gm 338?
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: motorola gm300
If you are referring to the receive audio, possibly the reason it is soft/weak are:
1. defective internal speaker - try using an external speaker;
2. volume control - try rotating back & forth till you get satisfactory level. In some cases, you may need to clean the inside of the volume control with an electronic contact cleaner. At worst is that it has to be replaced;
3. defective amplifier - between the volume control and the speaker is the audio amplifier. This is a single op-amp IC U501 (TDA1519A); and/or
4. muting - which is a bit complicated. This is triggered either by the squelch or by the CTCSS tone decoder. You may have partial/false muting. You need to check Q501 (MMBT3904) and its associated circuitry.
Other than #1, most fix would require opening the unit and familiarity with electronic circuitry & components, use of a DVM and soldering iron. Perhaps your best bet would be to seek the services of a qualified communication technician.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 08, 2007
ALLEN CLARKE
  • 47 Answers
SOURCE: troubleshooting gm338
Is the battery Ok?
check the on /off switch.
Check the PCIC chip.
Check the ASFIC chip.
To me it sounds like the on.off switch is faulty
Posted on May 26, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola GM300 Mobile
You're welcome!
Posted on Aug 27, 2008
Does anyone sell a universal longer antenna for a motorola talkabout 5000 2 way radio. 1 guy said add coaxial .I only want the antenna to be 7 long or so
it is not the length of the aerial that matters but how it is wound there are books that explain the function of aerials and the relationship between windings and wave length or cycle so by studying the books and having a fibreglass fishing rod you can in effect may your own aerial to what ever length you like
next thing you can do is join a club for radio operators ( ham or otherwise) and you will be in an organization that will help you to get the best from your radio
Jun 29, 2015 | Motorola Radio Communications
Can you give me the specs on: Motorola radius GM300 radio? Model: M43gmc29c2aa wanting to know how many channels and how many watts. Thank you.
I think this is what you are looking for: Motorola Radius GM300 VHF 146-174mhz 16 channel 45 watt mobile (MDL# M43GMC29C2AA)
Jul 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
How to change frequency on gm300
To my knowledge the GM 300 can be programmed only with a DOS based programing software. Start with the DOS, not from the windows
Mar 12, 2009 | Motorola GP300 Compatible 2 Way Radio...
2 way radios
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Sep 14, 2008 | Motorola Radio Communications
Motorola GM300 Question
Check your antenna connections and coax for loose connections or damage. Also check your hand mic. See if the problem disappears if you turn on the radio without the mic attached. The two most common problems with a mobile radio are antenna and mic problems.
If you feel these are in order, it would be wise to have a tech look at the radio.
Aug 23, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola GM300 Base Station
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
May 19, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Radio Communications Logo
312 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
