Question about HP Office Equipment & Supplies
Printer taking too much time to print
When i give a print command priter start running but the printout is not coming, its keeps running for around 5 to10 minuts and then only the printout will come
please help to solve this problem
  • 26 Answers
Please perform the steps and check if it improves the printing speed.
1. Click Start or Windows Logo>> Control Panel >> Printers and Faxes or printers
2. In the Printers window, right click on the printer icon and click on Properties.
3. Click on Advanced tab.
4. Under this select the "Print Directly to Printer" option.
5. Click on Apply and OK. Now try printing.
Wish
Posted on Aug 01, 2009
Brother printer taking too long to eject a printout
I'm not sure I understand your question. It sounds to me like the printer is working properly. An inkjet will spit a text only page out faster than a page with graphic data on it.
Ink Jets print the images in a "Swath" pattern. This is what gives the page the step motion on exiting a printer.
Now laser printers, since they are intelligent printers, will build an image and then transfer the image, fuse the image and eject the page in one smooth operation.
But lasers would require a "Print Page" command from the datastream to force the page ejection or trying to print outside of the no print area on the page.
For example a PCL 5e datastream would issue a hex 0x0C command to eject the page.
PostScript wouold issue a "Showpage" command.
Don
Jan 29, 2010 | Brother MFC 4650 All-In-One Laser Printer
Alarm light keeps coming on after each page is printed. I have to hit the reset button before another page will print.
press the go button 3 times and it will give you a printout that shows the error, it most likely will be to clean the drum which you do by moving that little blue lever on the drum back and forth around 20 times. If it's a paper feed error, clean the feed roller with a damp cloth.
Aug 25, 2009 | Brother HL 1440 Laser Printer
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
2 document pending for print.i coud not print now.
hmm simply just click printer icon and cancel all the docs for printing then again give the print command and your papers will print
Mar 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
Estudio 352 is not help to take out printout from computer
Hello sir; When you make copy does it print? if there also no print out you better check the corona wire (charge & discharge) it should take care of you, if still don't work let me know.
Dec 30, 2008 | Toshiba Estudio 200L Copier
No printout
did you try to print a test page from the printer from setup button
Jul 05, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Printing takes a very long time
In this case you can bypass the spooler by the following steps:
1. Right click the printer icon & left click the printer properties
2. Click the Advenced tab in the printer properties.
3. Select the option PRINT DIRECTLY TO THE PRINTER & UNCHECK THE OPTION SPOOL THE DOCUMENT.
4. Click apply and ok.
5. Try printing.
Feb 08, 2008 | Office Equipment & Supplies
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Print server
Check the port configurations on both XP machines. It should have the IP address of the print server connected to the plotter.
Aug 01, 2007 | NetGear PS101 Mini Print Server Print...
52 people viewed this question
Seeker5211
Seeker5211
