52 error on hp laserjet p4515x - Office Equipment & Supplies
  • 40 Answers
Because laser-ray cannot feedback to laser control,apart of laser box for cleanning or something hiding.
Posted on Aug 01, 2009
Standard_top_bin_full_remove laserjet p4515x
The black lever where the paper comes out (right side) is stuck down, lift up to unstick.
this is temp. will stick again unless you clean it.
remove 4 screws undo the white lever that is attached to door
(right side)
lift up top
put upside down
look at black lever
there is a pad that has melted and is sticky
clean ( remove is best with flat screw driver) then clean
put back together.
solved
Jan 01, 2017 | HP Laserjet P4515x Printer
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Hwo do i repair error 52 in hp leserjet pro 400 m 410 dn
52 error is scanner related not formatter. HP has had issues with some serial number ranges of this printer having bad scanners which they will replace. You should contact HP regarding this problem.
Sep 09, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
Error 51.10 it appears when a send the order. hp laserjet p4515x
According to HP service literature, this is a temporary print error that requires you to turn off the printer and restart. Are you able to print a Configuration page from the control panel? If yes, then it is possible that your error is being caused by bad cabling or an incorrect print driver. If you can get the printer to come to ready, I would try upgrading the firmware by downloading from here. Easiest option if you are using windows is the Easy firmware update, which is the second option on this page. Download and follow the instructions.
Mar 29, 2011 | HP Laserjet P4015x Printer
Downl file now SEND RFU UPGRADE ON USB DEV PORT P4515X error on hp printer please assist
Hi
my friend your memory card is not working
you need to replace memory on printer
Nov 25, 2010 | HP LaserJet 4345mfp Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
170 people viewed this question
k24674
jasbo
jasbo
