Question about Wahl Health & Beauty
Power button stuck in 'Off' position
Wahl cutek ceramic hair straightener , code: za105,model: cutek. Power button stuck in 'Off' position, unable to remove all screws, can get to 2 out of 4! Any ideas on dismantling so I can release the power button?
My CHI button is stuck on off, how do i fix it ?
Posted on Oct 11, 2009
How to open wahl super trimmer model 1591/1592
Push the blade teeth away from the trimmer body, it will just click off. Undo two screws behind blade, undo one screw at rear of trimmer from the bottom. That's it cases will now split apart.
Jan 19, 2013 | Wahl The Peanut Hair Trimmer
I lost my directions for my remington wet 2 straightner.
you should use towel then use it. Then you take the right position of your hair . This is do you some days after 1 week you get you target
Jun 27, 2011 | Remington S7100a Wet 2 Straight 1 Inch...
Hello Fixya team , I have a Remington model number GP-1200 Hair straighter that have some power cord problem , I just need some instruction how to open the straighter , if is their any service manual...
Sry my english is not so good, iam from germany, today i have solved this problem, You have the button whre you can save it that it holds his posiotion on the side with the open Lock you need to remove the Button, then you see a screw, remove it und push the string out, (then the button on the other side cames outside) now you have in 2 items and can easily take apart.
Jan 02, 2011 | Remington S6500 Sleek and Curl Ceramic...
HOW TO PUT BACK BLADES ON WAHL FLAIR 8745 MODEL
you should place the moving blade first on the stable blade,then screw the 2 blades to the clipper
Oct 23, 2009 | Wahl Flair 8745-200 / 8745-210 / 8745-220...
Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Sep 16, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
What the difference betwen conair wet-dry ceramic straightener and the infinity nano system
the differnece is that rhe wt-dry ceramic straightener is only 20% ceramic and burns your hair while the infinity nano system straightener is better but still leaves your hair with a burnt smell. If you have that burnt smell it means your hair is frying. Use a damage repair shapoo and conditioner
Dec 25, 2008 | Conair MN250CS Hair Trimmer
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Health & Beauty Logo
394 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
