Question about Canon imageRUNNER 400S Copier
F-0-0 Sir this code is on my mechine how i reset the programs of mechine
    Guru:
  • 389 Answers
Heat lamp or thermal fuse is wrongor wrong connectons
Posted on Sep 14, 2009
Brother reset code
turn of the mechine and press menu key and turn on the mechine and follow instructions
Dec 12, 2013 | Office Equipment & Supplies
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
How to remove the drum unit. please give me the direction with figuers. Error E0020-0081 & please provide me error codes details
HELLOW SIR MY NAME IS ASLAM SORRY SIR I HAVE NO FIGURES IN UR MECHINE ?SO FIRST U WILL OPEN THE FRONT DOOR AND TAKE A SCROO DRIVER U WILL LIVE A UNIT OPEN THE 3 SCREW S U WLL CHANGE UNIT
Nov 12, 2010 | Canon iRC3100 Printer
In my office we have a SHARP AR 5127 copier. i have replaced the cartridge and it's worked one month and after showing the error call for service U2-40. I want best solution. Plz. give me soluti
u2-40 is communication problem in mainboard,try to replace the toner cartridge. or reset by programming. here the programme...on the mechine then # interrupt 0 interrupt. if mechine go sleepmode pls press 14 and start.
Feb 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
Dec 28, 2009 | Sharp AR-M237 Copier
The cooling function is always on. The dryer will not heat regardless of the mode that it is in Normal/Timed/Manual
hi your mechine will be having a option called reset button by reseting it your mechine program ill be reset and come s to normal state
Aug 24, 2009 | LG Dryers
Compressor winding problem
A 3 PHASE COMPRESSOR THAT LOOSES A LEG WILL NOT RUN. SO BE SURE YOU HaVE all 3 legs and check the legs across to each other with your vom, and then to ground. any leg not showing up for the compressor wires may indicate you need a NEW CONTACTOR. Check this and see if you get the same readings.
Jun 19, 2009 | Jenn-Air Freezers
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
Xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Jul 09, 2008 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
old marine
old marine
