Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi vs-5041 -after a few hours on, the tv goes black
I have a mitsubishi vs-5041 -after a few hours on, the tv goes black. after leaving it off for a couple of hours it works again. but for only few hours. any help would be appreciated.
thanks,
Chuck
  • emailchuckjr Aug 01, 2009
    thanks, sounds like i have to have someone come out. i just didn't want to spend 200+ on an old tv. is the tv worth being repaired?
  • 20 Answers
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Posted on Aug 01, 2009
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Blurry mitsubishi projection VS 5041
there a one or more defective tube needs to be replaced is typical efect when is tube end of life.
Jan 02, 2010 | Televison & Video
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi vs-5041 picture intermittently goes off
my guess is convergance ic but to troubleshoot it the best soultion might be to get a can of freeze and spay it on the IC while the problem is happening and or tap the board/ic's to see if you have a loose connection,
Nov 29, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Projection TV. Works for a couple of hours and then the picture shuts off
Very often older Mits CRT's develope a slow leak of coolant
onto one of the circuit boards....various problems arise,depends
on where the drip lands....even a good tech can miss the drip
evidence.....I have pulled the chassis to the shop only to find
"wet" area under well-lit conditions.................T.
Nov 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Jun 12, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Jun 01, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
284 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
