Skullcandy double agent- SD slot madness.
About the same happens to me; by pressing the play/pause long for 3 seconds till the blue light comes up, then its starts flickering from blue to red and shuts off. at first i thought it was that i was holding it down too long, but thats not it. DX (HOW DO YOU TURN IT ON?)
the first time i plugged the headphones using the USB port into the comp, my comp said ''Device intaller error-- Windows could not load the installer for Volume. Contact your hardware vendor for assistance.'' (WHAT DO I DO? WHOM DO I CONTACT?)
so instead, i took the SD card out of the headphones and put it into the slot in the comp. then i dragged and dropped the mp3 files into the folder. took the SD and put it back in the headphones-- it doest work. DX (i think you have to leave the card in the headphones and drop the files in that way). DDX (IS IT THAT METHOD?)
AND my SD card goes really deep into the slot (i dont know how far it is suppose to go)-- because when i slide it out a little further (while beening charged into the comp) the light is red. (IS MY SLOT BROKEN?)
it works fine plugged into my Zune though. -_____-
UGHHH. sucha' cool product, just wish it would function correctly. DX
please contact if anyone can answer any of the questions in CAPS.
umouiling@yahoo.com
btw, i was using a Windows XP AND Windows Vista.
Thanks, and sorry for the rant. i am very angry. D:
I read somewhere else that your file system of the SD-card has to be FAT16 and NOT FAT32 or NTFS. So maybe you should check that out...
Posted on Dec 28, 2009
I found that the sdcard slot had come unsoldered so it didn't turn on or charge, a bit more solder to all the pins got it going again.
Posted on Mar 06, 2013
Hi guy! one thing i had to do was convert all my music to mp3.. lots of music nowerdays is mpeg-4 so get switch sound converter.. its free!! give that a blast! and the sd slot is quite deep and awakward so just push till it locks in
hope this helps!
Posted on Sep 02, 2010
Hey I have the same exact problem and I am trying hard to find the solution and I havent tound one yet. Have you found a solution yet? I will message you if I find a solution.
Posted on Dec 27, 2009
I turn on my set and the power light comes on for 2-3 seconds then the set turns off. What causes this to happen?
F power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65411 65" Rear Projection...
I Have charged my skullcandy's for 2 days and when i click the play button to open the speakers a light just comes on when i click it then just go straight away PLEASE HELP
It is because your songs are a too high quality for the memory card. I'm having the same problem and I am trying to find a solution myself.
Jun 20, 2010 | Skull Candy Double Agent Stereo Headphones...
Skullcandy double agent not charging
Make sure you have the memory card in the unit or it will not charge. If that doesn't work call up the company and ask for a refund/replacement.
Feb 17, 2010 | Audio Players & Recorders
SkullCandy Double Agent Headphones won't charge or work
What I have seen is that some will just keep on charging for no reason but they wont turn on. What I did is that once I unplugged the headphones from the computer I took the SD card out and I moved the white switch-like thing towards the top of the card. Once I put my SD card in and tried to turn it on again it worked. Try this if your headphone wont turn on but will still charge, it should work.
Dec 25, 2009 | Audio Players & Recorders
My ps3 has a fuzzy screen when playing on it this only happened a few days ago should i tae it back as it is only 4 weeks
first try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
then take it back as these steps will not void warrenty
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
New SkullCandy Double Agent - SD card does not work
at first I also have a same problem with U, yes it might be the battery U should recharge. Try to plug the USB then wait for around 1 hour. The indicator will turn into RED when its charging.
After the charging complete please remove the USB cable then press the play button for 3 sec and wait until the indicator turn blue. The music will play.
Aug 20, 2009 | Audio Players & Recorders
Skullcandy double agents won't play some tracks.
They can only be in Mp3 format or WAV I think. I know Mp3 for sure. If the music is in any other format you will have to reformat the music in order to get it to play. It's something really obnoxious about the headphones which could've been easily avoided. Just look up a program like Switch or an online converter for free. It's pretty simple.
Aug 05, 2009 | Audio Players & Recorders
The best advice I can give for you is to just call up Skull Candy or even better yet, just fill out the warranty information on their website if there is a defect with the headphones. When I called they were real easy to talk to and helped with me with what I needed in order to get a new pair of Double Agents. If they are less than 90 days old you can still get a new pair if you have a receipt when you send them in. If not they will still give you a 50% coupon off any of their product. Hopefully you registered your headphones when you bought them. They basically come with lifetime warranty, and Skull Candy is willing to work with you all the way through. Hope this helps.
Jul 03, 2009 | Audio Players & Recorders
Skullcandy double agent headphones won't play music
Try to check the SD card, switch the protector, then try to play it again by pressing play button 3sec (the indicator will turn into blue), then the music will play.
Apr 19, 2009 | Audio Players & Recorders
1,013 people viewed this question
 Grubhead
Grubhead
