Question about Kenwood KDC-MP435U CD Player
Deck will not turn on
My vehichle sat for about 16 months with this deck in it. when i left it worked fine. when i tried turned on my vehichle today, the reciever didnt turn on. i checked all wiring and fuses and everything was fine. is it time to purchase a new one? could just sitting have killed it? thank you
  • 162 Answers
It is unlikely that just sitting killed your system.
over time fuses can build up corrosion in them just like the terminals on your battery.
try changing them.
Posted on Aug 01, 2009
Car wil not start will not turn over at all. the radio and lights work fine, battery was replaced about 2 months ago
check the battery cables are not loose at both ends. when the battery was replaced you may have loosened the cable at the starter end or the ground end?
Dec 15, 2013 | 2006 Hyundai Sonata
Garmin 1200 suddenly stopped loading up....
I am haveing the same problem
poky345@yahoo.com
Can not seem to find any reason?
Mar 31, 2010 | Garmin nuvi 1200 Car GPS Receiver
Strange noise from deck of Toro LX426
The engine wont have an impact with the deck because its belt driven. It sure sounds like you have a bad set of spindle bearings,just turning it by hand you wont hear any noise it has to be going fast to hear it. The noise may be coming from your clutch instead of the deck,and it sounds like the deck. Have these things checked out.
Aug 09, 2009 | Garden
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
Deck fades out when i bring the second deck in (records I mean)
are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
May 24, 2009 | Technics SL-1210 Turntable
Engine stalls
DId you remove the existing gas or just topped it off? If you topped it off, I would dump the fuel and replace the fuel filter, after that I would clean the carb (Spray cleaner).
May 20, 2009 | Garden
SAT button it does not work, you can not turn on or off the DISH
First press the SAT button at the top left hand side of the remote and release. Now try changing channels. If this did not work press the menu button twice on the receiver. It will usually be behind a pop open door on the right of the receiver. I f your receiver does not have these buttons you can access the system info screen by pressing the power button on the receiver while holding down the arrow left or right key.
Once you have come to the SYSTEM INFO SCREEN press and hold the SAT button on the top left side of the remote until all lights across the top light up. Then key in a two digit number e.g. 01-16 and press the #key. then press the record button and the remote address for the location you are trying to control should change to the number you keyed in. If this is the second location tv that was giving you issues exit out of all the screens on the receiver location tv and go to the other location and try the remote. If it is the tv where the receiver is located then you should now be able to use the remote to maneuver the yellow cursor across the screen. If you need further assistance please let me know. Thanks for using Fix Ya.
Dec 11, 2008 | DISH Network IR Remote Control
Picture is distorted blurred lines
i had same problem. Mine was a product defect issue and although it was out of warranty Sony repaired as this is a problem that they have had with lots of these cameras. Call Sony.
In English: 1-800-222-7669
Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
Feb 10, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
My amp keeps going into protective mode.
try to lower the SLA option on ur deck maybe the amp is pulling to much current from the battery try putting a battery with more AMPS
Jan 06, 2006 | Jensen LXA400 Car Audio Amplifier
Kenwood KDC-MP435U CD Player Logo
133 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
