Question about Panasonic Lumix DMC-FZ7 Digital Camera
CHANGE DPI I CAN'T SEEM TO CHANGE MY DPI ON MY DMC-FZ7.EVERY PICTURE HAS DPI OF 72??
Yes, every picture has a resolution of 72 ppi. This can be changed later in an image editing program on the computer.
Posted on Jul 09, 2008
How do i get the date stamped on the pictures from my panasonic lumix dmc-fz7
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
May 19, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
How do i set my tz6 to 300 dpi
DPI (dots per inch) is an output parameter and is irrelevant to the camera.
Let's say you took a picture and want to make some prints of it. You make a 4x6 print and a 8x12 print. Those will be printed at different DPI settings but It's exactly the same file from the camera, just printed at different sizes. The camera can't know what size prints you might make from the picture, so it simply puts in a default value.
If you really want to change the DPI setting as recorded in the file, you need to do it on a computer using a photo editing program.
May 07, 2014 | Panasonic DMC-ZS1 / DMC-TZ6 Digital Camera
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
How do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic DMC-TZ3 72 dpi problem
Sounds like Photoshop's setting, or default setting, is to import picture at its maximum size. If you RESIZE pic on Photoshop, it shoud automatically increase DPI while reducing physical size.
The other thing to be aware, TZ3 defaults to a certain jpg compression. You can minimize compression of data with settings options on TZ3, but I doubt this has anything to do with your PhotoShop issue.
Also, in SIMPLE mode you can select a physical size for photo, even after pic is taken(resize), on camera.
Hopes this helps.
May 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Resolution
Many cameras will take pictures at only 72 dpi. Changing the resolution causes the camera to change the size of the picture in terms of pixel dimension (ie 800x600 vs 640x480) but always at 72 dots per inch. A photo editing program like Photoshop can change the resolution to whatever you need.
Dec 13, 2007 | Samsung Digimax 4010 Digital Camera
DPI
Have you looked at the number of inches that 72 dpi is spread out over? 72 dpi is the standard default setting for any digital camera. What matters is the size that you actually print it at.
Sep 07, 2005 | Panasonic Lumix DMC-FZ3 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
259 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
