Question about SanDisk Audio Players & Recorders
Find root directory of sandisk clip sport - SanDisk Audio Players & Recorders
What tools are needed in order to fix the clip on my eclipse fit clip?
It is not cost effective to fix an mp3 player like that. Here is a model that should be built a bit better.
http://www.bestbuy.com/site/searchpage.jsp?st=sanza+mp3+http://www.bestbuy.com/site/sandisk-clip-sport-8gb-mp3-player-black/3761028.p?id=1219093519912&skuId=3761028 http://www.bestbuy.com/site/searchpage.jsp?st=sanza+mp3+http://www.bestbuy.com/site/sandisk-clip-sport-8gb-mp3-player-black/3761028.p?id=1219093519912&skuId=3761028
Aug 08, 2016 | Eclipse Audio Players & Recorders
How can I remove SlotRadio advertisement from my Sandisk Sansa Clip + 8Gb. I can't find any SlotRadio files in both UMS and MTP modes.
You will need to manually reinstall the firmware from the Sansa Website
Current version is 01.02.15 (at this date 1/30/11)
On your clip the version number may be followed with an "a"
Your clip should be at least 50% charged or greater before following these steps
DO NOT use the Sansa Updater
1. Download the current firmware for your Clip+ from the Sansa Website
2. Save the zipped firmware (clipplus01.02.15.zip) to a folder you can easily locate (Downloads)
3. Create a new folder naming it what you wish.. (Sansa Firmware)
4. Open the downloaded zipped file(clipplus01.02.15.zip) using something like Winrar
5. Delete the file clpp_data.dat (This is the slot radio ad)
6. Extract/unzip the remaining file clppa.bin to the new folder (Sansa Firmware)
7. Plug in your Sansa Clip
8. Drag and drop (copy) the clppa.bin file into the internal memory or root of the clip
9. Unplug the clip from the USB port on your PC
10. The firmware will update and the media will refresh.. and you will no longer have the Slot radio Ad on your clip
Good luck
I have three clips.. 2 of the 2 gb.. 1 of the 4 gb and now a plus 8 gb.. and yes..I too found the banner ad annoying as all get out.
Washoe
Jan 18, 2011 | SanDisk Sansa Clip MP3 Player
Do I need to use Windows Media player (I don't have it) to download music on to my sandisk clip, or can I do it another way?
No, you do not need the Windows Media player.
All you need is access to your Sandisk clip through the transfer cable supplied. Best if used in a USB 2.0 port. (You get the best performance)
Most are plug an go. With windows machines... this is referred to as "Plug an Pray." :)
Have your file manager up and check the list of drive letters.
Now plug in the Sandisk clip transfer cable. Another drive letter should be assigned and it will appear in the file manager listing.
Now go to the directory where you have the files stored to transfer.
Copy them over the new drive letter under the correct directory and you should be done.
Hope this helps!
Small easy to use go anywhere Music player: 1BY1
Larger but highly recommended MediaMonkey
Free version available.
Dec 26, 2009 | SanDisk Sansa Clip MP3 Player
The PC will no longer recognize it. I've tried downloading the driver from the sansa website and manually attempting to fix it will no vail
Support for the Sansa Clip support information is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/4303/kw/clip/r_id/101834
Correct link for updating the Clip's firmware:
http://kb.sandisk.com/app/answers/detail/a_id/300/related/1
When MANUALLY installing firmware:
Check the version of your player to have the matching firmware download for the player, as described in the updating firmware link.
Going to the Sandisk forum site for the Clip firmware download:
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=15109
Note: read the instructions how to perform the firmware update.
1. Choose the correct version for the player.
2. Connection mode in Windows should be automatic, when not recognized in Windows or with MAC and Linux use MSC mode ***** .
3. Extract the zip file on the computer first.
4. Next put the unzipped file on the player in the root directory.
5. Disconnect the player.
6. Restart the player: the firmware update should restart now.
*****Note:
Switching to MSC mode for Sansa Clip:
Method 1: through the menu
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
Method 2: forcing, using the buttons / switches
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
Need more help ? Just post a comment.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
My sansa 8gb clip shows 'empty' for all music when in fact there is 7gb of music on it.... and i cant sync on any more songs. What should i do?
have you synchronized the 7gb music that is placed on the clip
select all the music and go to the properties remove the hidden attributes and read only tick mark
apply settings restart your device it should work now and show all the music in all music and make sure the music files are in the root directory of the drive that is they are not stored inside any folder
Jul 10, 2009 | SanDisk Sansa Clip MP3 Player
I am having trouble installing the installation cd sandisk that came with my sansa clip mp3 player. I have windows xp and just installed the sp2 pack, but the cd will still not install. Thanks.
pleae check if the cd includes a driver for won xp- it might not
put in cd manually, browse it using the win xplorer, until u find someting like setup.exe
in the main directory of the cd or in the driver directory, double-click7 execute it.
this may tell u if the driver software on cd supports win xp - else get the right driver here:
http://www.sandisk.com/DriverDownload/driverList.asp
folow the instructions on the screen,
enjoy
Jun 21, 2009 | SanDisk Sansa Clip MP3 Player
I lost my disc can i still download
You can put music on it by doing the following (assuming vista/XP environment):
Connect it to your PC using the provided USB cable.
Open windows explorer and navigate to your Sansa Clip.
Click through "sansa clip", "internal memory" to the "music" directory.
Drag and drop MP3/wav files to this directory. Feel free to create subdirectories.
Your music will be accessible after doing this.
Be aware that the clip ignores your directories. It will look for artist, album, and title tags to categorize your tracks. You may have to look for your tracks in the "unknown" album directory when playing if your tracks don't have these (ID3?) tags.
Good Luck!
JakeE333
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Psp video playback
all you do is go to google and type i avs for psp then u install avs then download a video clip go to avs and drag the video clip in to this box and then u clik ok then it will automatcally go to your psps
Oct 14, 2007 | Sony PlayStation Portable (PSP) Console
162 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
