Question about Philips Magnavox 9P6034C 60" Rear Projection Television
All of a sudden a ''ghost'' picture that comes and goes. Shows a double picture with a change in colour.
    Brigadier General:
  • 4,090 Answers
Your antenna could be moving on its pole just enough to out of tune
Posted on Aug 01, 2009
How do I fix my Visio tv when the screen suddenly goes almost black and white?
Hi Evan
Essentially it's a computer inside a modern Flat Screen TV these days. Not a lot that the average person can do...
But... if you feel capable of opening the back....
Once you get inside and check for loose or poor connectors,
I would be looking for leaky Electrolytic Capacitors.
Usually in the power supply section.
Look for brown fluid leaks on PCB & a very slightly puffed out or bowed top on the cap. (ready to explode)
Take a picture of suspect. Take note of Polarity (black stripe) & write down uf & voltage & temp values.
eg 1000uF @ 25v
To prove you are on the right track, you can connect a similar rated Cap across (in parallel) the existing Cap.
Depending on space etc. Even by short extension wires.
Power up & see results. Fault Gone or Not?
Then...
Unsolder & Remove suspect Cap & try to replace with higher voltage rating & slightly higher uf capacity depending on space available around the components.
Good Luck
See
How to Replace an Electrolytic Capacitor
Oct 30, 2015 | Vizio L37 Television
Just install a new 42"
Can you please describe the problem with a little bit more detail? Are you saying that the pictures are coming up with a ghost effect? When the pictures are freezing what exactly do you mean, as in when changing inputs you can still see the picture there but gradually goes away?
Jan 10, 2011 | Zenith Televison & Video
Why is my tv ghosting and colours mostly pink and green
I need to know the make and model number . If you are handy I may have a solution that will save you humdreds
please contact me at techman32k@yahoo.com
Aug 02, 2009 | Televison & Video
Goes from normal to weird colour saturation blues and reds seperated and ghost double images
It sounds as if the video card driver is on the blink. Try going to Toshiba.com and look for video driver upgrades for your system and download. Let me know if that works.
Thx
Aug 01, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
"ghosts on sony projection tv
Hi friend
its colour wheel problem you should change it,,,first check if any burnt parts resistors,,,,,common problem is colourwheel,
check it...........thank u,,,,,,
May 03, 2009 | Televison & Video
Double image
TRY COLOR CONVERGENCE IN THE MENU
Mar 26, 2009 | Samsung HC-P4752W 47" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
