Question about Tomtom Go 730 GPS
Screen deactivated & a red circle with an 'X' flashing
Screen is deactivated and there is a red circle with a white 'x' on the middle. the circle is flashing. opposite the flashing circle is the picture of the my tomtom Go730. below the flashing circle is what appears to be a picture of a disk. this is what comes each time i switch it on
    Brigadier General:
  • 4,090 Answers
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Posted on Aug 01, 2009
How do I fix Samsung ue40h5030ak led tv that the screen is flashing red green blue white
LCD panel fault. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 26, 2016 | Samsung Televison & Video
How do i turn on the flash?
On the menu there should be an icon that looks like a yellow lightning bolt with a red circle around it and a red line thru it (this means that the flash is off)....in the lower right hand corner you should see a white lightning bolt. Tap the red circle 2 times and you should notice that the yellow lightning bolt now stands alone and the red circle and the red line has been removed (now your flash is on). Note: Each time you turn on the camera and you need flash, you will have to make this adjustment...I hadn't figured out a way so that it happens automatically..
THANKS.
Apr 11, 2011 | Vivitar Cameras
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Red circle in middle of screen color is way off
You have a problem with the light engine. Hitachi has extended the warranty on some of these. This is a major expense with major labor charges. Better get in contact with a local Hitachi authorized repair facility.
Apr 30, 2009 | Televison & Video
Red box, white circle
There are many icons listed for your camera in the manual. If you do not have the manual you can download it online at www.nikon.com. It is a little hard to locate, but it is there and it has diagrams of all the icons and what they mean. If I can I will try to send you a diagram.
Aug 22, 2008 | Nikon Coolpix 2200 Digital Camera
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
Tomtom Go 730 GPS Logo
281 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
