Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
Belkin router not working with 2wire wireless adapter
My roommate has a belkin router and i have a desktop with a 2wire 802.11g/b wireless adapter. I cannot pick up her network but can get others in the area. Other people who come to the house are able to connect to her network just fine. What do I need to do?
  • emduper26 Aug 01, 2009
    i have the name of her network and tried to enter it in to the list of preferred networks but nothing changes. I know the password, but i don't know if it's the same as the network key.
  • 746 Answers
Your SSID should be same then you can connect that network.
Posted on Aug 01, 2009
Unable to connect to home ATT 2wire with new Belkin USB wireless
AT&T 2Wire routers function as both routers and modems. You can disable the router functionality by placing the router in bridge mode. In bridge mode, the 2Wire device functions only as a modem and forwards all incoming traffic to the device behind the 2Wire router. For example, you can use a different router instead of the 2Wire's built-in router by enabling bridging mode -- the router behind the 2Wire device will get the external IP address, and the 2Wire router won't interfere.
Step 1Type "Homeportal/management" (without quotes) into your Web browser's address bar and press "Enter" to access the Management page in the 2Wire router's Web interface.
Step 2Provide your 2Wire router's custom password, if you set one. The router comes with no password set.
Step 3Click "Configure" under Broadband on the Management page.
Step 4Type a period (".") into the "Disable PVC Search" box.
Step 5Set the value of the "VPI" box to "0" and the value of the "VCI" box to "35".
Step 6Set the "Connection Type" to "Direct IP" and click "Submit."
Step 7Click the "Configure Services" link on the Management page.
Step 8Uncheck "Enable Routing" and click "Submit."
Jan 31, 2013 | Computers & Internet
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
2WIRE Router, Belkin Card, and 10 vs. 13/26 digit encryption key
I would give you two options
1. to change ur wireless key to fit to this card
2. u can still let windows configure wireless for this card as well
However would like to have a clearer report about the problem
Jul 05, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
On my 2wire 3800HGV-B internet on wireless is lost!!!??
To fix this issue all you have to do is,
First Confirm the model number & version number of your router and check for FIRMWARE update.
It may be quiet difficult for you to do up date firmware.please call toll free number"2 wire" and ask them help you to update it..
..........Hope this information is help full for you ALL............
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless
Try to restart the the Wireless Router if that doesn't work then go to:
Start-> Run-> CMD [Enter]
type in: netsh winsock reset [reset]
restart the pc... when it boots back up go back to CMD prompt and type in:
net start [enter]
this will start the net services
you may need to go type in Services.msc in cmd prompt and go all the way to bottom and enable Wireless Zero Configuration... If that doesnt work you may need to reinstall Drivers on room mates PC.
Dec 09, 2008 | Belkin (F5D7001) 802.11g/b Wireless...
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wireless adapter used to work, then stopped, then worked again, now can't be detected...
you mean that the adapter is not being recognised by the pc as a usb device, this adapter works better on a usb2.0 port, not as well on a usb1.0 port, depending on how old your pc is, try other ports., but you must uninstal the belkin driver from add/remove programmes, then install the driver again and inset adapter in a different usb port than before.
the adapter should then be found and click install driver automatically, but leave the cd in the drive as it normally picks the driver up again from the disk on it's own even after installing it yourself.
When installed i would recommend using windows wireless zero configuration (windows own software) instead of the belkin software, to do this right click on the network icon and select enable WZC (windows zero config), as this is a more stable programme for connecting your adapter signal to the router
Personally Belkin is poor in my opinion, netgear has better software and drivers, but it's belkin you have, so follow the above and it should be ok.
Sep 09, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
247 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
