If you have a package then land line and mobile charges are included in the package and are not separated
There is a package the Telstra sell that is for 2 land lines , net connection, land line hire and 25 gig of data for around $120.00 a month and all calls local, national and international are free except for 1300 numbers
however if the land line is inoperative you are entitled to a refund on that rent cost for the period it is not available and if incoming calls are redirected to your mobile , that cost is on the caller
ring accounts and make your point or contact the ombudsman and make a complaint or shift service provider
SOURCE: INCOMING CALLS FRM LANDLINE CANT BE AUDIOBLE
UR PHONE SET OR ITS SPEAKER OUGHT TO BE OUT OF ORDER.
SOURCE: Using UK mobile while on
Yes you will need to dial the international code of UK to call from Turkey.
SOURCE: call forwarding
no it is not possible u should have the concerned phone/mobile in your hand for which the calls have to be forwarded
SOURCE: Internet & my mobile phone
You will need to use Optus to access the internet from your mobile (the data rates are way cheaper than Telstra anyway) as there is the internet connections are completely seperate. You'll still be able to check your Bigpond email though. Check the Telstra website for the "SMTP settings" you need.
restore of the system software, I would go to when you restore.
