How do i make the air conditioner warm on cold days?
    Champion:
  • 363 Answers
I assume this is a window unit you are talking about. Unless it is a combo unit you can't get heat from the a/c only. If you are talking about a heat pump, then it is automatic through you thermostat.
Posted on Aug 01, 2009
AIR CONDITIONER
Could be a list of things including low on freon, low pressure switch, relay, or the a/c clutch on the compressor.
Jun 30, 2012 | 1997 Lexus ES 300
It has been blowing warm air. It will blow cold air for about 5 minutes and then warm air all over agian.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Goldstar R5050 Air Conditioner
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Air coming out of vent very low and not cold
Try cleaning the coils with a wire brush and soapy water.
Aug 11, 2009 | Whirlwind FH-778 Air Conditioner
1998 gmc sonoma air conditioner - not cold
Check the magnetic clutch is engaged on front of a/c pump, have the motor running, a/c on and fan on high, if the centre hub is static the pump in not switched on, this can happen when the gas pressure gets low.
Aug 05, 2009 | 1998 GMC Sonoma
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
