Question about Kodak EasyShare C360 Digital Camera
On my Kodak C360, as soon as I remove the batteries to put fresh ones in, the date/time setting rests to 2005/1/1/12:00. This doesn't happen on my C340. Is there a tiny internal memory battery that is at fault?
  • 300 Answers
Yes, there is a small internal battery that keeps the time and date going while camera is turned off. If you're interested, I can help you locate it as I have all the schematics as I work in a Kodak service center. My e-mail is toms.safranovs@gmail.com
Tom
Posted on Aug 01, 2009
Wont power up ,kodak easyshare c360
Please make sure that you're using fully charged battery
Remove the battery, press and hold the power button for 5 seconds and then reinsert the battery..
Try using a different battery to check whether the issue is with the battery..
You may also check the battery poles using a multimeter to confirm this if you do not have access to a different battery..
If the issue persists, service may be required.
Thanks for understanding.
Jan 05, 2011 | Kodak EasyShare C360 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
C360 powers up and immediately powers down again. New batteries in camera.
No solution, according to Kodak online help - camera must be returned to Kodak for repair.
Jan 11, 2010 | Kodak EasyShare C360 Digital Camera
Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EasyShare M1033 Digital Camera
Camera suddenly stopped working--an error message flashed, then camera shut off-put new battery in--nothing happens. (kodak c360)
Usually when the camera shows an error mgs. it needs a repair
However Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
Nov 23, 2009 | Kodak EasyShare C360 Digital Camera
Red light blinking then turns off new batteries
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
If your cam use AA batt.:
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare C360 Digital Camera
Batteries
I had the same problem......I went to the store that i bought the camera from and i bought a kit that contained four rechargable batteries, a battery charger, & it also came with a car cord that goes into your cigarette lighter so you can charge a set in your car. PROBLEM SOLVED for $26.00 + tax.
I take a whole lot of pictures (freelance photographer) and I ALWAYS have one fresh set. As soon as the set in my camera goes low i throw them on the charger and put a fresh set in my camera. By the time the fresh set goes low, the set in the charger is ready.
Sep 07, 2008 | Samsung S630 Digital Camera
Kodak Z700 not firing up
I have the same problem. Removing the memory card and then starting up seemed to fix it; the camera would then start up ok even with the card in.
Mar 08, 2008 | Kodak EasyShare Z700 Digital Camera
Camera frozen
try removing the memory card first then turn it on ...
see what happens
the problem maybe with your card and not with the camera
Nov 16, 2007 | Kodak EasyShare C360 Digital Camera
"Date/Time have been reset."
This is the first time you turned on the camera, or the battery has been removed for an extended period of time, or the battery is exhausted. Reset the clock.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare C360 Digital Camera Logo
216 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
