SOURCE: How can I connect external speakers to my Vizio VA26LHDTV10T?
Used the earphone plug with amplified speakers.
Testimonial: "That's my answer"
SOURCE: VIZIO VA26LHDTV10T SCREEN IS CRACKED
I have a Visio Va26LHDTVV10T with no picture. When you power up it comes on for a second and fades out. Seem that the upper right corner where channel is comes on first. sound is fine
SOURCE: My Vizio (VA26LHDTV10T) Tv says
You get this issue because the TV does not support the resolution your xbox is displaying at. I had the same problem with my PC since I use the TV as a monitor. The TV will do a max resolution of 1360x768 so, you need to set your xbox to that resolution or the one closest to it as long as it is under that number.
SOURCE: My VA26LHDTV10T Vizio TV was
What to do depends on the current symptoms of the set. If there is no action at all when attempting to turn it on, then there is a major power supply problem. This can be caused by a number of things. If the set attempts to start but can not, then that indicates a different type of problem with different fixes. Can you update this with a more detailed description of what happens?
Thanks,
Dan
SOURCE: Can i use an rca RCU704MSP2N universal remote for a Vizio VA26LHDTV10T
0048,0028,0016,0025,0061 are the setup codes to check. If you wish to get more codes, 3 digits, five digits etc; check this link. Setup proceedings to some popular models of remote controls is given too.
