Question about Acer Projector Lamp for PH110, PD113P
The lamp when booting just turns on and in a few seconds just turns off
  • 110 Answers
Change your lamp's power suply
Posted on Aug 01, 2009
Turns itsel of after a few seconds
Not the lamp - if it were the lamp it would never turn on in the first place! Check for a defective component in the power supply area especially the capacitors. When their value changes, they are responsible for all kinds of erratic behavior. Items will not turn on, shut down after a few seconds, etc.
Aug 24, 2015 | Vivitek D950HD DLP Projector
Displaypanel on toshibasatellite turning off after logon.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 09, 2013 | Computers & Internet
Lamp replace light is still one even though i replaced the bulb
I'm having this same problem. The Ready light is on Green and the LAMP light is on Red. Replace Lamp light is also on. The device turns on, displays the blue SANYO boot screen for a few seconds, then shuts off.
Jul 14, 2010 | Sanyo PLC XP41 Multimedia Projector
Hello, i have a problem with my TV. When we turn on TV, after few seconds the screen turns off, and green power light starts to blink, after that the picture returns back on. And in few seconds this...
The problem you are having is likely the lamp is bad and needs replaced this happens when the lamp gets weak replace lamp should fix your problem part # is xl2400
May 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
We have a Sanyo XP57 projector. Occasionally (not every time), the unit boots up and the lamp comes on for a few seconds before turning off and all the lights on top of the unit flash. Turning on and off...
It's possible that your lamp could be coming to the end of it's life. Do you have a replacement lamp to try. One more thing to check, how is the air circulation around the projector? Is the filter dirty? These are things to check.
Good Luck
Sep 28, 2009 | Sanyo PLC-XP57L LCD Projector
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
TV turns off after a few moments but come back on again after a few seconds
Remove the lamp and check to see if the connections of the lamp and the lamp driver(ballast) are ok or they look bit burned.Also the lamp should always be replaced first especially if is two years old or more.
Check to see how many times the error indicator flashes.If it flashes 5 times then the lamp driver is probably defective.
common problems are lamp and lamp driver(ballast).
let me know if you need more help.
Good luck.
Sep 19, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Acer  Projector Lamp for PH110, PD113P Logo
127 people viewed this question
Top Acer Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
