Question about Ace Hardware Eljer Toilet Tank Flush Lever
The flap goes down too quickly
Before the bowel empties you have to hold the handle down to get a complete flush the chain is tight so i dont what else to check
  • 98 Answers
Just a thought, you might try to get a piece of chain at a hardware store and do it yourself.....might cost $3, maybe less. There is also a screw on the top of the lever the chain and float are attached to, you can loosen or tight it to change the way the toilet flushes.
You can also check on line at:
www.howthingswork.com
Posted on Aug 01, 2009
When flushing, only a small amount of water leaves the tank, and the bowl just empties. The chain has a little slack to close, however, it does not hesitate at all. When flushing, the chain lifts the...
Try holding the handle down until the tank empties completely. If the tank leaks into the bowl during or after refill, the flapper is defective and not sealing correctly.
Jun 21, 2017 | Kohler Memoirs toilet tank with Stately...
When I flush my toilet bowl the flap doesnt stay open long enough for a complete flush.
Hello, W/D here.
If you look at the chain that comes up from the flapper to the flush handle, you'll see that it attaches to the flush handle with a clip. Open the clip, and take up more of the chain, to where the chain has just a little bit of slack in it when everything is at rest. This should raise the flapper higher.
Best regards, --W/D--
By the way, the water in the tank is clean!
Apr 09, 2011 | Home
Flapper closes way to quick. Have to hold handle down for complete flush. This is in an Amer. Stand. toilet. I have adjusted the chain and the flapper dail with no help. I work in the plumbing Dept. at...
Hi, American Standard uses a special large type of flapper that is designed for it. If I recall correctly,
It is black plastic with a device designed to delay the closing of the flap. It also has a special chain that is not like other flappers. Home Depot should stock these flappers. Fluidmaster makes a version of it that they sell.
Hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
When i flush the toliet the flapper stays up and will not fall back down so toliet keeps trying to fill
adjust the chain that connects the flap to the handle give it some slack but not so much as to get chain laying under the flap good luck and hope it helps
Nov 09, 2010 | American Standard Home
Flush does not completly empty bowl. Must hold down handle for it to work. Tightened flush handle chain.
replace the flapper. this usually corrects the problem. make sure you get the right flapper for it, not a universal flapper, they don't work.
if you are unsure what model you have, remove the lid on the tank, and look for the model number stamped into the back of the tank.
Aug 17, 2010 | American Standard Cadet 3 Right Height...
How can I adjust the float, I have wellworth complete solution class five (11471-0). It seems like the float goes down quickly, with emptying the remaining water. I have set the right water level, and yet...
what happens is the float is not staying open for long enough, by shorting the chain that goes to the flapper might help but you can only shorten it so much or the flapper does not close all the way then the toilet is just running and running. No you don't want that so the other thing you can do that might work is when you go to flush the toilet just hold the handel down for 5 seconds this will keep the float up and open for the Right amount of time. Other wise the other way to fix it witch is a old school trick is that you need to find a nice small piece of foam, witch floats and is about the size of a old half dollar and as least half inch thick, you place that on the chain that goes to the flapper so when the toilet is flushed the flapper will float and stay open . IF you do this just make sure to use a good piece of foam and secure it properly where it wont come off the chain.
May 18, 2010 | Kohler K-11470-0 White Wellworth Complete...
We have to flush at least two times before we get a complete flush. any suggestions?
Some of these come with a flapper/flush valve that is made to operate in partial or full flush. Look at the underside of the flapper. Is it a cone shape that has a pencil sized hole in it (or two)? This cone is supposed to keep the flapper afloat during the flush, but the holes allow it to flap back down early. Its a pretty cheezy way to pass the low water requirement, but they get away with it. If you hold the flush handle down for a few seconds (until the tank empties) you will get a full flush, but only when you need it. Or you can just buy a replacement flapper that doesn't have the hole in it. They are cheap and easy to replace, but you will use more water.
Jan 17, 2010 | Toto Drake ADA Compliant Toilet with...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Toilet will not flush fast enough
the chain that connects to the flap has too much slack you have to ajust it by switching the chain up a little so the flap will open all the way
Dec 29, 2008 | American Standard 2294.011.020 Afwall...
Ace Hardware Eljer Toilet Tank Flush Lever Logo
286 people viewed this question
Top Ace Hardware Home Experts
Donni Steen
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
