Question about LG Flatron L1750S 17" LCD Monitor
"power saving mode"
I just buy it new and i think the cables r fine, but when connected to the pc it give "power saving mode" and dont transmitt any data from pc..any solution? i have vga card 128
  • zezo_4milad Aug 01, 2009
    The old monitor is not working at all so i buy the new. i have connected the monitor and all connections then powered on the pc and the monitor. It has a menu button but all buttons dnt make anything during pc working.when i power on the pc it give me "power saving mode" like standby.even when put the installation cd nothing appears!!! i dnt knw about type of connector for now..so finaly wht is the solution u see?
    Scholar:
  • 142 Answers
Have you connected and then power on PC? does this monitor works any other PC? Is old monitor works in your PC? Some models of monitor has menu functin from what type of connector use to recieve data but they also automatically adjast it. Try to find if your model has any. If PC works in others and all connections is all right its better to bring your monitor back to shop.
Posted on Aug 01, 2009
  • Sulkhan Abesadze
    Sulkhan Abesadze Aug 05, 2009
    I think you video card is dead or your pc is hanged. You may have onboard video adapter and also have separate one installed. if so check have you connected to aditional video card? in this case onboard dont work until you unplug inserted. If video is dead then after power on some continious beep will occure. Check is your processor leads continue flashing (red one) or is on all time? Try take off CMOS battery for 10 minutes ant then power on.
How do you get music to save on a new 4gb memory card on a nokia E5 instead of saving in phone memory
Transfer music from a computer
You can use the following methods to transfer music:
• To install Nokia Ovi Player to manage and organize your music files, download
the PC software from www.ovi.com, and follow the instructions.
• To view your device on a computer as a mass memory device where you can
transfer any data files, make the connection with a compatible USB data cable
or Bluetooth connectivity. If you are using a USB data cable, select Mass
storage as the USB connection mode. A compatible memory card must be
inserted in the device.
• To synchronize music with Windows Media Player, connect a compatible USB
data cable, and select PC Suite as the USB connection mode. A compatible
memory card must be inserted in the device.
To change the default USB connection mode, select Menu > Ctrl. panel >
Connectivity > USB and USB connection mode.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Nokia E5 Cell Phone
I have set one lock code for my nokia n97 mini model. I forgot that code now...
follow this steps :
Tools Required :
- Nemesis Service Suite (NSS)
- Nokia PC Suite
- Data cable
Regain Your Security Code
Steps:
1. Install Nokia PC Suite
2. Install Nemesis Service Suite (NSS)
3. Connect your phone to your PC with data cable. If the phone prompts, choose default mode or PC Suite mode (DON'T OPEN PC SUITE)
4. Open Nemesis Service suite (NSS)
5. Click scan for new devices button (on top right corner of NSS)
6. Click Phone Info button.
7. Click Scan button.
8. Click Permanent Memory tab.
9. Click Read button.
10. It will read the permanent memory file and save it on the disk at following path.
C:\Program Files\NSS\Backup\pm\.pm
11. Open the .pm file using Notepad.
12. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there.
13. Like 5=31323334350000000000 (Example)
14. Abandon the red fonts.
15. So, 12345 is your security code. (Example)
Now, here is how to reset your security code.
Reset Security Code
Steps:
8. Under Power Mode, click Local and then click Change button. At this part, your phone should restart, and you should see the text Local mode across your phone screen.
9. Under Production Data Edit, click Read button. The textboxes should now contain values.
10. Check the Enable check box beside Product Code.
11. Click Write button.
12. SelectTools button on top
13. Click Factory Settings tab
13. Tick Full Factory button and click Reset button.
14. Final step, go back to Phone Info and click Normal then Change.
Now your security code should be 12345.
Mar 03, 2011 | Nokia N97 mini Smartphone
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
My phone doesnt conect to my PC.
1. Make sure that the theme that you have downloaded is compatible with Nokia 5310.
2. Yes, there's a way to connect the phone to the PC without using the PC Suite. Follow the steps below:
* On your phone, go to Menu and then go to Settings.
* Go to Connectivity and then select 'USB data cable'
* Then connect your phone to the computer
NOTE: The computer should recognize the phone as Mass Storage Device. You may now save any file to your phone and it will be saved directly to the memory card.
Have a great day!
May 16, 2009 | Nokia 5310 Cellular Phone
Imissed the data disk & cable now the batery
if u hav missed the data cable u may hav to buy a new one
 the griver pc suit disk can be downloaded from internet in sonyericsson.com
Mar 05, 2009 | Sony Ericsson w580i Cellular Phone
I have a new flatron monitor...screen is blank except when I first turn it on a meesage reads "power saving mode" and then shuts itself off again...HELP!!!
Check if the monitor data cable (one with blue connector) is connected to the PC's VGA connector at the back of the PC, properly.
Jan 03, 2009 | Computers & Internet
Scanner problem
Hi s2009edwards, double check the USB data cable from the printer to the computer. Power off the printer. Than, unplug the data cable connected to the printer & re-connect it. Follow the data cable to the PC & unplug the cable & re-connect it. Power on the printer & wait until its done making noise. Try scanning again. If it fails to complete & you receive the same error message than buy a new printer data USB cable & replace the old one.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=76&SRCCODE=WEBGOOCOMP&cm_mmc_o=7BBTkwCjC-p8ByplCjCabTwyKbywgfCjCmH4
If the HP director software is installed (Which it should be).
You can open HP printer software there should be an HP icon down by the clock. Right click on it once & left click open or launch. If you did not install your HP printer software suggest you do so.
Mike
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hey i have prob in iso games
STEP 1: CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
STEP 2: FORMAT YOUR MEMORY STICK
In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
STEP 3: EXTRACT THE SAVED GAME
This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
STEP 4: TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
STEP 5: EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
STEP 6: VERIFY TRANSFER OF SAVE DATA
To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
That's it, simple and smooth.
Oct 16, 2008 | Sony PlayStation Portable (PSP) Console
Memory card is not displayed in motorokr e6
Hi malik, you just insert the memory card and press it for a while. and see whether the memory card has been detected or not.
Don't buy any new card or adaptor, it's the problem of your phone.
Jun 26, 2008 | Motorola Mobility MOTOROKR E6
LG Flatron L1750S 17" LCD Monitor Logo
215 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
