Question about Aiwa LCX-110 Shelf System
MyLCX-110EZ plays for some hours and than loss the power for eg. 10hours.äfter this time it is available by reconnecting to get power, but today just the Display is lightent Herbert
What is a game session timer?
It's used in gambling or for any game that doesn't have a real endpoint. The timer lets you know after a set time (eg. 60 min) how long you have been playing for. The option will then be given to keep playing or to stop. It's to help you not lose track of the time and end up playing for hours on a time.
Jan 17, 2013 | Games
My car losses power and shuts down at any time and will not start back up for at least an hour if i disconnect the battery and reconnect it will start back up and run fine for anywhere from a day to a...
Hi and welcome to Fixya!
As a first course of action, have the car be diagnosed. A scan tool can help, it will list the faulty codes and by then you'll know the fix.
Hope this helps and thank you for using FixYa!
Jan 03, 2011 | 2004 Chevrolet Tracker
I put coke (soda pop) on my battery posts to clean them and now when it starts I have to hold my foot on the gas. 97 Jeep Grand Cherokee limited.
It sounds like you have a brand new problem besides sticky battery posts. Make sure that you have reconnected any additional wiring to the posts. Mainly the ground wire. Usually it's a 12 guage short wire that connects to the negative battery post and connects to the inner fender well farely close to the battery. How long was the battery cables disconnected from the battery? More than 10 minutes? Most newer vehicles that have been disconnected from battery power for 10 minutes or longer after being reconnected, has to re-learn how to work or run. Fter being diconnected from power that long a time erases the memory from the computer.
Sep 21, 2009 | 1997 Jeep Grand Cherokee
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
RCA color Model X13101G5 ChassisTX825XB loss of vedio and sound fuse not opened, set will play for hours not go on next time in use and then go dead again
DID YOU EVER SOLVE THIS PROBLEM?
Jul 30, 2008 | Televison & Video
Battery back up is limited to 1 hour only
Did you do a full cycle charge when you got the Laptop? When you buy the Laptop you have to use the computer on battery till the battery dies and then charge battery for 12 hours and you repeat that another time. Most likely your battery it is damaged. Maybe you call the company and they might replace it for you.
Jan 16, 2008 | Acer Aspire 3680 Laptop
Aiwa LCX-110 Shelf System Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
