I can't use the file button or the ones on the steering wheel
SOURCE: Red Set button underneath the steering wheel
I believe this is for your tire pressure sensors. If the tire pressure in one of your tires drops it will alert you with a light on your dash. When tire pressure is restored, press this button to reset the sensor.
SOURCE: connect bluetooth phone to hp dv9000
have a look at this manual:
http://h10032.www1.hp.com/ctg/Manual/c00186949.pdf
hope this helps
kind regards
SOURCE: motorola h710 bluetooth will connect to phone but no audio
I disabled the bluetooth from my phone. I then turned off my phone and rebooted it. Once the phone was turned back on, I paired it up with the bluetooth and then it worked. So disabling and removing everything and starting over worked.
SOURCE: can't find bluetooth connection on laptop to connect 2cell phone
This computer has no bluetooth, check here.
You will need to buy an external bluetoothe adapter like this ones:
100m Wireless USB 2.4ghz Bluetooth ...
100M Wireless USB 2.4GHz Bluetooth ...
BLUETOOTH 1.2/2.0 USB 2.0 100M
IOGEAR GBU311X Bluetooth v1.2 USB ...
IOGear gbu301
Motorola OEM Bluetooth Adapter PC850. ...
SOURCE: 06 gmc truck steering wheel button
That is for your on star phone that came with the truck. As long as you are paid up on the on star and have minutes on your phone you purchase them seperately. You can press the button and use the phone the little speaker is really a microphone and the speakers for your phone come thru on your radio.
