Question about iLO Televison & Video
I need a manual for Ilo DVDRHD04 recorder - iLO Televison & Video
    Top Expert:
  • iLO Master
  • 52,781 Answers
Try Googling (ilo)(DVDRHD04)(manual) without parens.
Posted on Apr 24, 2018
3 Suggested Answers
SOURCE:
  • 38 Answers
SOURCE: ILO DVDRHD04 won't copy dvds. Says
The 04 version of this player only uses DVD +R or +RW it will not reconize -R or -RW make sure you are using the approved DVD media for this unit
Posted on Mar 04, 2010
SOURCE: Need a manual for an iLo DVD Recorder, Mod. #DVDRO4
need a copy of the DVDR04, help set recorder and clock.
Posted on Dec 04, 2011
ILO DVDRHD04 PARTS
I understand that Funai corp makes these iLo DVD player/ recorders but when I spoke to someone, they did not recignize the model number. Their number and address is :FUNAI CORPORATION Customer Service Tel :1-800-605-8453 http://www.funai-corp.com 19900 Van Ness Avenue, Torrance, CA 90501 Good Luck
Jun 05, 2007 | iLO DVDRH04 DVD Recorder
Where can I buy a digital tv tuner to replace the analog tuner in a DVDRHD04
Generally recording machines fitted with an analogue tuner can only continue to be used to record digital tv by using a digital set-top box.
It would not be practical or economic to remove the internal analogue tuner and replace it with a digital tuner unless the person is a highly skilled and experienced repairer.
Digital set-top boxes are available from all sorts of outlets at all sorts of prices. Many surplus boxes can be found at boot sales, garage or yard sales or charity shops at very low prices.
Most boxes have the minimum of connections and often offer only a scart output but some of the older, more expensive and usually better quality boxes also contained a UHF tuner in a similar way to the old vhs recorders so even older tv sets could be used with digital even though no scart input was fitted.
Dec 03, 2015 | iLO DVDRH04 DVD Recorder
Jan 31, 2010 | iLO DVDRH04 DVD Recorder
Apr 16, 2009 | iLO DVDR04
I need a remote for my ilo dvdr04 recorder. where can i get it?
Go to walmart and get a Philips universal remote, they have the ilo code listed. I have two of them...even though the remote isn't set up like the original ilo remote, you can still record, burn, finalize, and edit. I have the dvdrhd04...which is going into the shop tomorrow to replace the dvd burner, but the hard drive still works like a charm.
Again, you'll have to play with the remote a bit....ARC gets you into the menu and (.) while playing will get you into edit mode, but into another menu when not playing a recorded item. I've used it so much now that I can barely use the original remote. ha ha. The perk is that you can set up your dvd, your tv, digital box and other things to run on one remote.
Hope this helps.
Denise
Apr 11, 2009 | iLO DVDR04
Remotew control
I also have an iLO DVDRHD04. I recently purchased the Philips remotes at Wal-Mart and they have the code for the iLO. You'll have to play with it a bit, but all the functions will work, even though they will not be labled in the same fashion as the original remote. I had to just press buttons and make notes until I got it figured out...but it will work.
Jan 17, 2009 | iLO DVDRH04 DVD Recorder
DVDRHD04 Timer setting
ON YOUR REMOTE, SELECT AND CLICK "TIMER". DETAILS OF THE SCHEDULE WILL POP UP. USE THE ARROWS TO SELECT WHICH ONE NEEDS CHANGING AND CLICK "ENTER". MKAKE YUOR CHANGES AND GO DOWN TO CLICK ok AT THE BOTTOM OF THE SCREEN.
Apr 21, 2008 | iLO DVDRH04 DVD Recorder
User Manuel
This is the website to download manuals for the ilo DVD Recorders. Took me forever and alot of different searches, but here it is:
http://www.ilohelp.com
Mar 24, 2008 | iLO DVDR04
Replacing dvd player/burner on iLo DVDRH04 DVD Recorder
I Have ILO DVRHD04 and my front buttons sto to work when i use the remote works ok... when the unit is of I turn on from the front paner works ok try to turn off from the front buttons is not work and the lite in the front go crazy only when i pres stop & play button and on fo button... what is the problem... The remote work ok play stop edit or recodring
Mar 12, 2008 | iLO DVDRH04 DVD Recorder
Televison & Video Logo
35 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
