Question about Cobra Radio Communications
Cb problem have a cobra 19dx iv with a 2ft magnet mount cobra antenna swr is good, receive is good, but muffled output
  • sunyjim Aug 02, 2009
    So took the mic to a very unhelpful cb shop, at least confirmed it was ok. Completely unwilling to suggest anything else though.
    My next suspect was the antenna. The radio and mic were new. I know i hooked up to good power coming off the back of the cig. lighter, so the antenna I got from my father in law was the next suspect. So I bought a new lil wil antenna with the intentions of taking it back if it didn't work. WOW does it work, clear with awesome reception. I figure the actual issue was the cable, after confirming it was working with the new antenna I learned of father in laws old habit of closing the window on the antenna wire. I suspect it's just crappy inside, and am suprised the SWR came out ok with it as it was
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Which output is muffled, transmit (modulation audio) or receive audio?
If you are referring to the receive audio, initially, have you tried an external speaker? If it works good, then it would be an internal speaker problem; if not then others to check would be:
  • IC1 - KIA7217AP audio IC;
  • CM 10 & 15 - audio output capacitors 470uF / 16V.
if it were transmit / modulation audio, try replacing the mic.
Please postback updates.
Good luck and thank you for asking FixYa.
Posted on Aug 01, 2009
  • Louie  Role
    Louie Role Aug 02, 2009
    I understand and appreciate the update. Magnetically mounted antennas are always compromised on SWR since the ground plane is not electrically grounded. There is a matcher that would result to a low SWR even if in reality, the radio is splattering all over even to itself.
    Still, glad that things worked out.
2 out of 5 signal reading on cobra cb radio
You'll need to find another CB radio for someone to check to see if they are receiving your transmission.
Aug 16, 2012 | Cobra 19 DX IV CB Radio
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
My cb radio changes my kenwood in dash unit mode when I key the mike
You might try grounding the CB and the Kenwood. It seems that there is stray rf floating around. Check your antenna. Make sure it is getting a proper ground. If mag mount; make sure base of antenna and where you put it are both super clean. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Oct 21, 2011 | Cobra 19 DX IV CB Radio
Cobra 19dx iv when i key up it swings all the way to a 9 is there any way to set swr,s without a meter
Just buy a factory built antenna/(it should be close) Buy you a magnet mount RADIO SHACK job(works). If your indoors buy ANTRON A99(set at 1.3 SWR factory). If it keys 9 db then that equals 4 watts output thats OK.
Apr 02, 2011 | Cobra 19 DX IV CB Radio
I Have A Cobra 19dx It Puts Out Good But I Can Only Hear A Short Distande
check the swr's on the antenna. all shops should do it for free just to check them. WE DO here in texas.. but if antenna isn't install properly then it may be high swr causing short distance.
Dec 12, 2010 | Cobra 19 Ultra II CB Radio
High swr's on cobra 29 ltd
Tom
Feb 09, 2010 | Cobra 29 LTD CB Radio
Have not used my cobra for some time ...sine someone need my K40 antennae more than me. Just put it back in service with a new magnet mount 36 inch - can send and receive in USB and LSB ....can here in the...
Center the antenna on the vehicle, then check the SWR on channel 1 and channel 40.
with the switch in CAL position, key radio and use the swr/cal knob to set the meter so the needle is just touching the end of the red area on the right-hand side of the meter.
Once calibrated, unkey and switch the switch to SWR and key up again. The lower the reading, the better. If the SWR is Higher on 40, the antenna needs to be shorter.. if its higher on 1, then the antenna needs to be longer.
if it dont transmit period on AM, then there's an internal glitch :)
Jan 24, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
High SWR
the problem is in the antenna cable. the lenth of a antenna cable must be divisable by 3. try replaceing cable with a 18 foot cable that should fix the problem.
Apr 11, 2009 | Cobra 19 DX IV CB Radio
Static and Recieving Problem
make sure people are talking on the channel it may be no one is talking . the static tells you it is receiving something. the cobra 19 and sister radio magnum sold at wallyworld are notorious for having bad solder joints on their boards.
Aug 27, 2008 | Cobra 19 DX IV CB Radio
CB transmission
Hello 64driver,
Make sure the radio is grounded properly and that the SWR is around 1.2:1, 1.3:1 is good but try to get it to 1.2:1. Also take a power output reading while keying the mic. To do this with your power meter put it in-line with the CB and your antenna and key the mic you should get about 4 to 5 watts PEP. If this is the case your unit is putting out the proper power level, if not have the power amplifier checked by a qualified repair shop.
I hope this helps
Shuttle83
May 13, 2008 | Cobra 19 DX IV CB Radio
Radio Communications Logo
254 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
