Question about Brother HL-2070N Laser Printer
Paper jam i waqs ptrining and in the middle of printing the power failed. The paper jammed in the middle and i can not get the stuck paper out. usually I can take out the jam but this time it is way down there nad i cannot get the jammed papeer out
  • 46 Answers
1.Remove tray and paper stuck in that area.
2.Remove drum/toner unit, clear any paper in that area. Sometimes you may have to remove the toner from the drum unit because there may be paper caught up in there.
3.Turn machine around and open back door, release the two blue leavers by moving them down, this releases the pressure in the fixing unit and then remove any paper.
Posted on Aug 29, 2009
    Scholar:
  • 143 Answers
Take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
Posted on Aug 01, 2009
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Says there is a paper jam and to open top cover but I do not see a paper jam there. I took out the toner cassette but do not see the paper jam.
    When your reports paper jam for any reason, whether there is paper jam or not, most times you need to go thruogh paper jam clearing procedure to have your printer printing again. So please follow the procedure below:-
    Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
    Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
    Put off the printer and unplug it from its power source.
    Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
    (If the printer is a DeskJet, otherwise ignore this step) Now pull out the cartridge carefully and place it on safe surface. (Be careful not to place it where it may slide and fall. This could damage the cartridge)
    Site the paper that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer's mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
    (If the printer is a DeskJet, otherwise ignore this step) Return the cartridge gently and press it firmly inside so that you here it snap inside.
    Close all covers at the top, front or back.
    Power on your printer and you should be able to print again.
    Good luck and God bless!
    Mar 04, 2011 | Kyocera FS-2000D Laser Printer
    Carriage Jam
    If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
    Follow the steps for fix HP Printer Carriage Jam
    • Turn off the printer and open it to see where the paper is stuck.
    • Manually move the carriage toward the opposite side.
    • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
    • Reconnect the power cord and turn on the printer.
    http://www.fixya.com/support/t6088190-hp_7400_displays
    May 08, 2010 | HP Officejet Pro 850 InkJet Printer
    Will not print because paper always jams
    Perhaps there is paper still jammed inside the printer that you cannot see (or little bits from a previous jam)
    1) Turn off the power
    2) Disconnect the power cord and USB cable
    3) Open the rear cover and see if paper is jammed inside the cassette area. Gently remove any paper and make sure no little bits of paper are left inside
    4) Open the scanning unit (printer cover) and check that no paper is stuck internally. Be careful not to touch the components inside the printer.
    5) Reattach the power cord and USB cable
    6) Power On and retry your print job
    Dec 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
    How can i remove the paper inside the printer
    For the paper jam issue turn around the printer and open the back door to pull the paper.
    and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
    Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Carriage jam on hp photosmart printer
    The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
    Solution
    The print carriage is the device which contains the print head and moves left to right during printing.
    Figure 1: Carriage Assembly
    To resolve this issue, follow the steps below in the order presented.
    Step one: Print a Self Test
    Follow the steps below:
    1. Press the Setup button.
    2. Select Print Report and press OK .
    3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
    Step two: Clear the paper path
    Follow the steps below to clear the printer of any jammed paper and reset the printer.
    1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
    NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
    2. Open the top access door.
    Figure 2: Opening the top access door
    3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
    Figure 3: Paper jammed on the left side
    Figure 4: Top view of paper jammed on the left side
    Figure 5: Paper jammed on the right side
    Figure 6: Top view of paper jammed on the right side
    NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
    If the carriage is stuck on the right side:
    a. Check for any paper or object that may be restricting the carriage.
    b. Move carriage all the way to the left side.
    c. Check the paper path all the way to the right side and remove any paper still in the printer.
    If the carriage is stuck on the left side:
    d. Check for any paper or object that may be restricting the carriage.
    e. Move carriage all the way to the right side.
    f. Check the paper path all the way to the left side and remove any paper still in the printer.
    If the carriage is stuck in the middle:
    g. Check for any paper or object that may be restricting the carriage.
    h. Move carriage all the way to the left side.
    i. Check the paper path all the way to the right side and remove any paper still in the printer.
    j. Move carriage all the way to the right side.
    k. Check the paper path all the way to the left side and remove any paper still in the printer.
    4. Remove the rear access door or duplexer (if installed) from the back of the printer.
    5. Check for and remove any paper still in the printer.
    6. Replace the rear access door, and close the top access door.
    7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
    NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
    8. If the Power light is on steady, print a self-test page as done in Step one.
    If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
    Step three: Plug the printer directly into a wall outlet
    Verify that the printer is properly connected to a suitable power source by following the instructions below.
    1. Verify that the computer and the printer have a three-prong power plug.
    2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
    3. Try the print job again to see if this step resolved the issue.
    NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
    4. If this did not resolve the issue, proceed to the next step.
    Step four: Service the product
    If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
    Jan 05, 2009 | HP Office Equipment & Supplies
    Carriage Jam
    Step one: Print a self-test report Follow the steps below:
    1. Press the Power button to turn on the product.
    2. Press Setup on the product control panel.
    3. Press the right arrow button until Print Report displays on the control panel display, and then press OK . The self-test report prints.
    4. Analyze the results:
      • If the product prints a self-test report, there is no need to follow the remaining steps, because the error message might be false. Try to print something from the computer.
      • If the product does not print a self-test report, proceed to the next step.
    Step two: Clear the paper path Follow the steps below to clear the product of any jammed paper.
    1. Make sure the product is on, and then disconnect the power cord and the USB or Ethernet cable from the back of the product. Do not reconnect them until instructed to later. NOTE: Make sure the product is on before disconnecting the power cord. Failure to disconnect the power cord from the product can cause damage when removing jammed paper.
    2. Open the top access door by lifting from the front center of the product until the door locks into place. Figure 1: Opening the top access door c00786115.gif
    3. Note where the carriage is stuck and look for jammed paper. NOTE: The carriage is the device that contains the printhead and moves left to right during printing. A paper jam can cause the error message and the carriage stall. Paper might be jammed in different locations and might cause the carriage to be stuck in the middle of the product or on the right or left side.
    4. Remove any jammed paper. NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the product. Follow these instructions if the carriage is stuck on the right side or the left side of the product:
      1. Check for and remove any paper or object that might be restricting the carriage.
      2. Manually move the carriage to the opposite side of the product.
      3. Check the paper path all the way to the side on which the carriage was initially stuck. Remove any paper along the path.
      Follow these instructions if the carriage is stuck in the middle of the product:
      2. Manually move the carriage all the way to the left side of the product.
      3. Check the paper path all the way to the right side and remove any paper along the path.
      4. Manually move the carriage all the way to the right side of the product.
      5. Check the paper path all the way to the left side and remove any paper along the path.
    5. Remove the rear access door or duplexer (if installed) from the back of the product. To remove, press in the tabs on the left and right side, and pull it away from the product.
    6. Check for and remove any paper still in the product.
    7. Replace the rear access door or duplexer, and then close the top access door.
    8. Reconnect only the power cord (do not connect the USB or Ethernet cables at this time). If the product does not automatically turn on, press the Power button. NOTE: The product might go through a warm-up period of up to two minutes. Lights might flash and the carriage might move. Wait until the warm-up period is complete before going to the next step.
    9. Check the power light.
      • If the power light is on, reconnect the USB or Ethernet cable to the product, and then print a self-test report as done in Step one.
      • If the power light is blinking or not on and the carriage is still stuck, reconnect the USB or Ethernet cable to the product, and then proceed to Step three.
    Step three: Plug the All-in-One directly into a wall outlet Use these steps to make sure the product is properly connected to a suitable power source.
    1. Make sure the computer and the product have a three-prong power plug.
    2. Remove the product power cord from any power strips or surge suppressors, and then plug it directly into a grounded wall outlet.
    3. Try the print job again to see if this step resolved the issue. NOTE: If the product prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor might not be allowing sufficient voltage to reach the product. If this did not resolve the issue, proceed to the next step.
    Step four: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Nov 04, 2008 | HP Photosmart 3210 Printer
    I took Paper from the front now the it keeps saying carrage jam(hp Photosmart C7180 all in one)
    Oct 24, 2008 | HP Office Equipment & Supplies
    I need help.
    If your priter is showing a 241 paper jam and the paper stops in the paper tray or lower front, then you can replace the pick rollers to fix this problem. If the paper stops in the middle, then check to make sure the sensor flag in the middle left of the printer is clean and in place. If the jam is in the back of the printer then check the fuser rollers to make sure that they are rolling when the printer starts to print, check the exit sensors on the fuser, there are usually two flags, one on each side of the fuser. If there is no paper stuck in the printer, then make sure that all sensor flags are up and not stuck halfway down. Or check for dust in the sensors.
    Apr 04, 2007 | Lexmark Optra T614 Laser Printer
    Brother HL-2070N Laser Printer Logo
    197 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
