Question about Jet Saws
Need part number for 707200 tire - Jet Saws
I just kept looking until I found a supplier of band saw parts.
Posted on Aug 02, 2009
I have a Schwin Solution FS AL mountain bike. I would like to put road tires on it. It now has 50-507 (24X1.95) on the side wall of the knobby tires. What road tire would fit?
I have done a similar thing with my mountain bike. The first number is the size of your wheel. The second number is how thick your tire is. You can get any road tire that has a "24" in the first number of the 24X***. Depending on the number after the 'X' you will probably need to get an inner tube that falls within that size. Most of the inner tubes will have a range for that second number. If the number is too large the inner tube will not fit inside the road tire.
Jan 30, 2015 | Schwinn Mens Solution FS AL 24 Bicycle Red
My bicycle tire is 29x2.00 what is the number that goes with my tire, i have a atom sl3.0
The 29 x 2.0 is a correct size. There also are some other numbers on the tire. They are the metric tire size. The format for this number is 590-32 both are needed to get the right replacement tire
Sep 06, 2014 | Cycling
Tires for 92 bucik regal
If you have 15" mags, you will need 15" tires.
The way tire sizes work is as follows:
  • The first number (205) is the TREAD WIDTH in millimeters;
  • The second number (70) is the percentage of the specified tread width the measurement between the tread and the wheel is (which means that the distance between the tread and the wheel is 143.5mm).
  • The third number, 15, is the rim diameter in INCHES.
Do a little math and you can figure out the proper size tire for your vehicle with the after-market wheels you are using.
Aug 15, 2014 | Cars & Trucks
Bandsaw blade tension
It must be a worn part. It simply needs replacement. Try calling first your Jet or consult your manual.
Jun 23, 2013 | Jet 707200 10Inch Band Saw
I need to know what my tire pressure should be on my 2006 Lexus ES350
the tire pressure is listed on the tires. The tire pressure is determined by the tire itself so you will need to look at the actual tire you should see numbers like 16/205/60r and another number like 44psi you need the number with psi following it and that will tell you your Pounds per Square Inch needed for the correct pressure
Jan 16, 2013 | Cars & Trucks
I have a new JET JWBS-10OS. I bought it rather than a scroll saw because it is more versatile, but I do need it for scroll work. I purchased a 1/8 inch blade and had trouble with the installation. The...
I'm not a Jet tech, just a bandsaw owner.
First, when you are adjusting the tracking knob, are you turning the wheel by hand for several revolutions to be sure which way it is running before making another adjustment? After tweaking it, you should turn it a bit to let it settle in. Also, be sure to tighten the adjustment knob down before turning it on.
The bearing guides have more adjustment places than just the finger adjusters. On mine, a Steel City, I can move the entire guide holders back and forth, and can also move the entire guide set up back and forth. The guides are there to keep your blade from having too much movement while cutting. They are not supposed to actually touch the blade though. I adjust mine with a dollar bill between the guide and blade. If you have one guide that isn't exactly perfect, don't worry about it. The blade guard will also keep the blade from wandering.
I've never used my bandsaw for scrolling work, so am not familiar with the 1/8 inch blade. Should work if you can get your tire adjusted correctly.
Good luck.
I hope this helps. If it does, I'd appreciate a vote or comment. Thanks,
Handie Andie
Apr 03, 2011 | Jet 707200 10Inch Band Saw
What type of bike tires are they?
There are lots of different wheel sizes on bikes today (20", 24", 26", 700c, etc.), and lot of different tire widths for all those different wheel sizes. Fortunately, tires are marked with their size, so you just need to learn how to read those markings, and they are not complicated.
For the purpose of picking a replacement tube, there are just two numbers you need to know: tire diameter and tire width. These numbers are always written somewhere on the side of each tire. (Sometimes when tires get old the numbers are hard to see. Don't give up, just keep looking.) Here are some examples of what the numbers might say: 26×1.95, 700c x 25. Sometimes the there will be three numbers, something like this: 26×1-1/2×1-3/4. Don't worry about that, just remember the first number (26 in this example), and the larger of the other numbers (1-3/4 in this case). Sometimes there will be letters with the size (such as EA3 or S-6). Sometimes there will be another number or two in parentheses, for example (622) or (559-45). Don't worry about those letters and numbers. They are important for getting a replacement tire that fits, but not important for replacing the tube.
The numbers can be hard to remember. It's a good strategy to write them down somewhere to bring with you.
Dec 21, 2010 | Cycling
What tires do I need for Jeep Grand Cherokee, 2005
The numbers on the tire are on the tire.. Look at the sidewall.. The tire size is there.. also - go to - tirekindom.com and register,, and putthe car info in and the specs will be there..
Have a great day !
Oct 24, 2009 | 2005 Jeep Grand Cherokee
What kind of tires does my car use?? I have a scion tc 2005.. and im about to change its 4 tires for the first time.. but i was wondering if they have to be the exact same size.. any ideas?
Your tire size is marked on the sidewall of your tire, it will read something like this, P205/70R15. There may be other numbers or letters but these are the critical ones that the tire shop needs to fit new tires on your car.
You car is set up to run on a specific size tire but changes can be made, for any number of reasons, without too many problems as long as you know what to expect. Changing the P205 number will change tour speedometer about 2 mph per size. Going from P205 to P195 will slow the car down and going up to P215 will speed it up the same. The speedometer will read the same but the car will be moving at the new rate of speed.
Changing the middle number, 70 will make your tire wider or narrower and the numbers work backwards. A 60 tire is wider than a 70 tire. This can affect your gas mileage but one number won't be especially noticeable. If you are buying snow tires for winter then 75 is the best number for that. The tire is thin and cuts through snow to make contact with the road.
Changing the last number 15 requires you to change the rims. That number is the diameter of the rim and there really isn't much reason to change them unless you are customizing your car.
Price comes into play more than brand name. You don't need that $250 super sticky tire for normal every day driving which you can do just as well on a plain jane $125 tire.The sticky tires use softer rubber and wear out quicker.
Finally, do not believe anyone who tells you that all season tires are suitable for snow and ice. They work better than summer tires if you get caught in a freak storm, but they aren't suitable for everyday winter driving. If you live in an area where there is a considerable amount of ice on the roads throughout the winter you should seriously consider getting you tires studded for improved stability, handling and stopping. Hope this helps.
Oct 20, 2009 | 2005 Scion tC
Bicycle Tires Tube
look at the side of the tire for a series of numbers
Nov 03, 2008 | Sram 850 8 Speed Cassette 11-32t Mountain...
Saws Logo
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
