Question about Roland Music
How to reformat a vs840
Downloaded an update and now it wont go past the startup screen
  • Roland Master
  • 5,603 Answers
Go to the VSplanetcom site. There is a lot of help there for the VS recorders. You have to be careful as you CAN clobber the built in loader so that you cannot boot and recover at all.
Essentially, for the update, you have to do a MIDI update to version 1.05 and then a ZIP disk update to 2.05.
YOU CANNOT go from less than1.05 to 2.05 directely!!! Also a ZIP update to 1.05 doesn't seem to work.
Posted on Aug 09, 2009
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Tip
How To Take A Picture Of Screen (W/O A Camera)
On Your Keyboard, Push The Print Screen Button (May Say "PRT SCR"), Nothing Will Happen. Open Paint, Or Some Photo Editing Program - I Recommend Paint - And Go To Edit>Paste. It Should Paste A Picture Of Your Screen. Ready To Be Saved From Paint To Your Computer. Another Trick, If You Hold Alt While You Push The Print Screen Button, It Will Take A Picture Of Just The Active Window You Are On.
on Jan 31, 2010 | Yamaha Full-Size Keyboard
Interrupted update for effects card on Roland vs2480 Now on startup only numeric light light up and machine goes no further
Never interrupt an update especially to flash regardless as what it is because it tends to destroy the firmware. I not very familiar with this unit but manuals etc are on line. My suggestion is to contact the factory and see if you can do a reload of the firmware. Tell them what you did, you are not the first nor the last to do that.
Dec 19, 2014 | Music
D888 recorder/mixer wont boot up. Screen says "power on failure" initialize" appears that hard drive has failed. though I hear it running
The hard drive has probably failed. In spite of it rotating, the head servo and electronics has to work. I would recommend testing the drive in a computer to see if it works. You will likely have to reformat it after if it does work. FIRST look for obvious things in the D888 like cable that is partially off or loose.
Aug 05, 2011 | Korg D888 8 Track Recorder
How do i update my Firestudio Preject
  1. Go to http://www.presonus.com/products/Detail.aspx?ProductId=43
  2. Click downloads
  3. Download the software for your OS
  4. Open the downloaded software and follow on screen instructions
The following is OPTIONAL and can potentially DAMAGE or BREAK your device:
  1. If you wish to update your firmware open the universal control software
  2. click settings > check firmware
  3. then follow on screen instructions
Jul 10, 2011 | PreSonus Digimax D8 Digital 8 Mic...
MY korkg PA800 doesnt load the opperating system and it wont let me reformat it, all i get on startup is a clear screen and nothing else happens
I don't know if your keyboard has a lithium battery for memory backup but that used to be a symptom of battery failure in other synths. Here is a link to a forum that discusses all the various problems:http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=38399 Lots of reading buts lots of links and help.
Jul 08, 2010 | Korg Pa800 Synthesizer
My roland discover 5 wont tune - not to default 440Hz or any others - wont stabilize - and the bottom corner of touchscreen where it says"440 -Do it" for resseting to default concert pitch dowant work/...
The unit may have the problem that befalls the Palm Pilots where something gets under the escutcheon and presses on the touch screen at the edge which overrides any other inputs.
Another possibility is a stuck button. The buttons are usually scanned as a matrix and at startup if a button is stuck that can make unit unresponsive.
Without a logic analyzer and the firmware listing you likely would not get far if one of the logic chips has gone bad unless it can be found using freeze mist and heat gun..
Stuck buttons or touch screen is usually easily found without schematic.
Apr 27, 2010 | Roland Music
Formatting of Fostex MR-8HD won't complete
same problem. cant format the disk in computer either
gen__000@hotmail.com let me know if you fix yours
Feb 20, 2010 | Music
Not booting after upgrade to latest version
The latest version is version 2. First try downloading the update again here:http://www.korg.com/SupportResults.aspx?productid=271 Don't forget to download and install the latest Midi driver and USB driver as well. They are available at the same address. I couldn't get the FAQs section to work there so I couldn't look at it. If you still have trouble try contacting them or try this site:http://www.sweetwater.com/sweetcare/ Let me know if this helps.
Nov 29, 2009 | Korg Pa800 Synthesizer
Music Logo
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
