Question about Tamron Cameras
When i use my 17-35 tamron lens on my d200 nikon on manual, the fstop jumps around on it's own. I'm not changing it. Also, as I'm taking pictures, for example if i take 5 pictures in a row in the same area without changing my settings, some of them will be solid black. I'm thinking it has something to do with the fstop changing constantly.... is there a setting i should change on my camera when i use that lens? I don't have this problem with my other lenses
Hi. I had the same issue when I first got my D200 years ago and just happen to come across your post. It is a simple adjustment in your Bracket/Flash mode in your menu under e. Go to (Manual Mode Bracketing) and set it to (Flash Only) and then the F-Stop wont jump around on its own Hope this helps you out.
Posted on Sep 04, 2009
I have just purchased a Tamron 35-70 3.5 CF MACRO BBar MC Nikon fit lens. Are there any special settings/requirements when using the lens for macro photography. Thanks.
This is a macro lens, and I can't find it has an auto focus nor can I find if it has a chip, or even any electrical connection. The sharpness though should be good.
When you are using a non chip lens on a Nikon, you only can use it in manual. So you have to put the main dial to M. Then you have to focus manual and just take a shot. the result will be to dark or to light, unless you already knew hoe much light you have and dialled the aperture and shutter time in correct.
For macro you want a large aperture number, to have as much sharpness (large depth of field) so the best thing is to choose f 8 or 11 and turn down the speed till you have a good light picture.
I found a forum about this lens, but they did not say a thing about the specs.
Tamron Adaptall 2 35 70mm F3 5 CF Macro 17A
Check some results here:
Tamron 35 70mm 3 5 17A on the GH2
Jan 23, 2015 | Nikon Cameras
Is tamron af 35-90 compatible with nikon d200?
Tamron makes lenses with a variety of mounts. Assuming the lens has a Nikon mount, then it is fully compatible with the D200.
Aug 05, 2011 | Tamron AF 35-90 f4-5.6 for Nikon AF
Using 200-500 Tamron on Nikon d300. When I shoot, camera freezes. Clock and exposure readout next to it, on top panel, blink. Camera will not turn off, I have to take the battery out. Lens works...
Maybe there is something wrong with your batteries? Replace them. I had the same experience with my D200 and a Nikon 18-200 lens, later with my Nikon 10.5, Sigmaa 135-400. After replacing the battery everything worked as ever.
Mar 26, 2011 | Tamron 200-500 F5-6.3 DI AF Lens Nikon
The Quantaray 70-300mm lens
Only if you get the version with the built-in autofocus motor. The D3000 lacks a mechanical AF coupling so AF lenses which need to be driven by a motor in the camera body will require manual focussing.
Either way, you're far better manually focussing the Quantaray/Tamron 70-300mm: the AF performance is very slow, very noisy and hunts around a lot to achieve focus.
Although the Quantaray and Tamron versions are identical lenses, if you have to buy this low-quality budget model then go for the Tamron: it's absolutely no better lens quality (and usually the same price), but the manufacturer's warranty from Tamron is much better than Ritz and is internationally valid. If you resell the lens then the Tamron will have some value (not much though) and the Quantaray will be near worthless as it's not so widely known, and has a poor reputation amongst those familiar with the brand.
"Cheap" isn't always the same as "good value"...
Mar 06, 2010 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Prime lens
make sure the aperture ring on the lens is set to the minimum aperture number, (usually a orange colored number), i.e. f22,f32
Jan 23, 2008 | Nikon D200 Body Only Digital Camera
Download dark photos
If you want to post the EXIF data to show what the settings of the camera were when you took the picture, that would help. But a guess would be that when you took them, the lighting was not enough for the fStop and Aperture settings.
Nov 22, 2007 | Nikon D200 Body Only Digital Camera
Nikon d200
Hello jenmardi,
First, the fstop and shutter speed question ... For a lens of 70 mm I would use the manual with shutter speed at least 1/250 or 1/500, then the fstop I would set at 2.8 or just under this, no more than 4. You need as much light as possible, but not to drown it. The shutter speed needs to stay low (or other words, fast) to not get blur. For example, for a 70 mm focal length, you have to double it to > 1/140 (70*2) or if it's 100 mm then > 1/200 (100*2). This is if you just stand still or using a tripod. If you're hand holding, you have to go higher, like 70mm would be 1/200 or higher and 100 mm would be > 1/300.
This is 1/250, 1/500, 1/1000 etc or more than half (or double, however you want to look at it) of your lens focal length. The fstop can be pulled down 2.8, 3, 4, 5 etc the effect of lowering this is the depth of focus will change. But that's ok.
Next question, red or yellow in it. Make sure you have the disc in the direct view of the lights you're shooting under when you take the measurement. Make sure the custom WB is being used (of course) and that you are getting the Good reply from the camera once you click the shutter. For whatever is yellow or red you need to make sure you do not mix lighting. All lighting needs to be at the same Kelvin rating or the balance won't match between subjects/objects.
Read up on what the 500wt Kelvin conversion is and make sure you compensate the 250 wt Kelvin lights with the appropriate color filtration to make the 500wt and 250 wt Kelvin conversion come out to be the same. The sun is also a different kelvin than these, so you even have to compensate for it too, if it's part of the equation.
Happy snapping. You can visit my site to see some of the results I get with high speed, low lite concerts.
Nov 21, 2007 | Nikon D200 Digital Camera with 18-200mm...
Cameras Logo
166 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
