Question about Refrigerators
Ice cubes melting and then sticking together
I have a Kenmore 23.6 cu ft. fridge with a top freezer. It is about 16 years old. Lately, the ice cubes from the icemaker melts and then sticks together. We end up with one big chunk of ice instead of cubes. What could be the problem? Thank you.
    Problem Solver:
  • 19 Answers
If you have dispenser to get ice or water, there is a cover to it that opens and closes as you ask for ice. If that mechanism is not working it stays open all the time and causes your ice to melt because cold air scapes. You should be able to replace that yourself. Sears sells that part. It is not very expensive. There is a cover over the dispenser pannel. It should right behind it
If you Agur that suppose to turn the ice to dispense, that could burn up too because the agur can not turn all chunk of ice
Posted on Aug 01, 2009
Water seems to be leaking into the freezer before it reaches the cube maker. No water outside the refrigerator so I think the leak is where is in the back of the freezer wall before reaching the cube...
Actually your evaporator drain is clogged, take your freezer back panel off. At the bottom there is a drain hole, stick a flat head screwdriver and see if there is something blocking the drain hole. You will have to defrost your fridge first. Good luck!
Aug 20, 2010 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer area smells and ice cubes and butter taste off?
It sounds like the ice maker if equiped. Remove Ice bin and clean out,and try a lite spray of bleach or vinegar (don't mix) If the smell is still happening and comming from ice you may want to install a inline filter.
Jul 26, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Ice sticks together
the ice cubes stick together because the water level in the tray is to high and the cubes can not be separated so turn the valve on the wall behind the unit closed some to lessen the amount of water in the tray
Apr 05, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our kenmore elite bottom freezer is making a loud humming noise. It shuts off when door is open..and continues when door is shut. Temperatures are fine, no error message, it rarely stops..like it is trying...
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Sep 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore bottom freezer died, fridge not cold either
Please keep in mind, I'm attempting to diagnose the problem without being there and with little information.
You are most likely going to have one of five problems.
  1. Condenser fan not turning (Fan under unit)
  2. Defrost problem (Heaters bad)
  3. Coils under unit dirty
  4. Defrost timer bad
  5. Bad compressor (Vary unlikely)
These are listed in order as to be the most likely to be the problem. I would check them in this order if I were called out on a service call with this problem.
. Respond back if you need me to walk you through checking any if these.
Please rate solution
Sep 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 18.5 cu ft fridge - heavy condensation/ice build up
mam please check the settings of the freezer and the refrigerator settings should be in normal mode and if u find it in normal mode then the problem is here the temperature controler is not responding to cutt off and cutt in the freezer so please check this operation.
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
FRIDG AREA LIGHT WILL NOT TURN OFF
this is a problem, there is a relay on the board that is sticking. Unscrew your lights or it will melt the display and possibly the liner. There is a fix available, contact Sears they should have a service bulletin out for it.
Sgt 48
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er dh ken bot.fridge. 795.77552600
one thing to try first is make sure there is enough air flow in the freezer and that the airway between the freezer and refrigerator's is free and clear
Mar 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
354 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
