Question about Health & Beauty
My Wahl Senior Clipper make a noise on the front of the blade, I have send it to 4 Clipper shops and the problem is still their.
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
SOURCE: reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Posted on Mar 17, 2009
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
wiringlunati
  • 576 Answers
SOURCE: my wahl clipper is very noisy, what should i do to
First, they need to have a drop of oil put on the cutters every time they are used. Second, there is usually an adjustment screw on the side of them to adjust the travel of the moving cutter. Adjust that so that it completely goes across the slots in the stationary one, but not too far or too noisy.
Posted on Nov 25, 2009
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Posted on Dec 04, 2009
How to adjust Wahl Switchblade clipper. I had it serviced and when I got it back I have to push down hard to snap in blades
Not a clipper adjustment problem, Has the clipper had a new hinge fitted?
Once a blade has been successfully fitted to your clipper will it go back on easier? ( this is normal as the clipper will make the blade socket the right width?
You should only connect a blade whilst the clipper is running so that the lever can locate into the blade.
Repair Servicing
Jun 13, 2014 | Wahl Basic Dog Clipper
How to fix my wahl senior so it doesn't pull hair
It could be one of several problems, but the most likely problem is that the blade is too far back. There are two adjustment screws on the the blade -- loosen these a tiny bit, then slide the blade forward (away from the clipper) and then tighten the screws again.
Nov 23, 2011 | Andis 01690 Hair Trimmer
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
I lost my instruction manual. How do you oil the Wahl beard and mustache trimmer model 99180? Thanks, DJ.
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Jan 24, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
My hair cutting device is making the noise that it should but the blades arent moving so they are not cutting any hair
On the side of the clipper their is a slot move this with a screw driver until the noise stops, the blades should start moving
Oct 11, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Reassmbling wahl product
Sep 03, 2008 | Wahl 9765-301
Health & Beauty Logo
144 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
