SOURCE: Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
SOURCE: engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
SOURCE: looking for a manual on
Your best bet at possibly getting a manual are in the 2nd link below for the rotary hoe.
Phone numbers AU and NZ
http://www.masport.co.nz/CONTACTUS/CustomerServices/tabid/679/Default.aspx
Contact Masaport directly here: (form)
http://www.masport.co.nz/SUPPORT/ImageRequestForm/tabid/664/Default.aspx
You can use the Distributor locator here:
http://www.masport.com/DISTRIBUTORS/DistributorLocator/tabid/182/Default.aspx
There is one site that is a pay site that has ONE resident Masport person. I can not list it here but has outdoorsking in the address. FixYa TOS thing.... (web search!)
As far as any engine manuals. The engine type model and series are stamped into the air shroud not far from the spark plug wire. http://www.briggsandstratton.com Type in your engine model type series and you can download you parts and engine manual.
Thanks for Choosing FixYa.
Kelly
SOURCE: craftsman dls 3500 briggs and straton motor.
my craftsman dsl 3500 will start but wont move forward or backwards. whells wont turn
