Question about Philips 46PP9302 46" Rear Projection Television
My philips 46pp9302 makes a chirping sound when i power it on and nothing comes on the screen.
    President:
  • 3,130 Answers
Sounds like a common problem that a kit is available from a place that has tv repair kits, you can Google it and look it up .
larry dillon
Posted on Aug 01, 2009
  • James Lynch Sr Mar 27, 2012
    Yes your are correct Larry and they are called tv repair kits .com.
Alignment of the bulbs to converge
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Philips 46PP9302 46" Rear Projection...
My tv looks like 3D and has blue ang green colors how can i fix my tv
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Mar 12, 2010 | Philips 46PP9302 46" Rear Projection...
Red horz.tilts
Projection sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
  • Dull looking video
  • White looking video
  • Red/Orange looking video
Mar 03, 2010 | Philips 46PP9302 46" Rear Projection...
Philips 46PP9302 has no picture and is making a chirping sound within the case.
I had this exact same issue after I attempted to replace the convergence chips on my Philips 51PP9303H/17. It turns out my solder was not complete around all the pins, like I had missed a few spots. Once I corrected that and made sure each pin was completely soldered around the pin, my issue with the no picture and chirping sound went away. So if you were working on the TV's circuit board prior to this happening, I would say to double and triple check your soldering. If it just happened on its own, then it seems the solder cracked somewhere on the circuit board resulting in one of the components to loose its full connection and functionality. I hope this helps...
Jan 06, 2010 | Philips 46PP9302 46" Rear Projection...
Tv turns on then right back off
Does if make a chirp sound? If so see below...
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 04, 2010 | Philips 46PP9302 46" Rear Projection...
Problem with convergence. The 2 colors will not converge and I cannot correct the problem manually
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
Sep 30, 2009 | Philips 46PP9302 46" Rear Projection...
Beeping noise when I turn on my TV
www.TvRepairKits.com just added a kit for the "chirping set" problem.
Hope this helps,
Dec 03, 2008 | Philips 46PP9302 46" Rear Projection...
My Philips 46PP9302 46 in is making a chirping sound
A cheaper way is a DIY but it seems like this failure is not a DIY.
I would say that for a 5 years old TV that has been fixed twice and requires a repair again, I would save the $500.00 to buy a new TV instead of fixing this one.
Good luck.
Jul 29, 2008 | Televison & Video
Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Jan 22, 2008 | Philips 46PP9302 46" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
