Question about Nextar M3-02 GPS Receiver
My nextar m3-02 gps says cannot start the main navigation engine it says to reinstall the application and try again but I do not have the program
    Brigadier General:
  • 4,090 Answers
Ontact6 Nextar. if you have proof of purchase they might allow a doenload If not you will have to pay for a new set
Posted on Aug 01, 2009
When i try to use the navigator it comes up with a gray box that says fatal application error application adeona.odysseycore has performed an illegal operation and will be shut down. if the problem...
This indicates that the unit suffered internal hard drive failure. Unfortunately support is not available at this time as both the nextar website www.nextargps.com is down and their customer service phone number does not work as well. You will need to get a new GPS unit,
Sep 24, 2011 | Nextar 43NT GPS Receiver
My naxtar gps wont load into the maps. it loads through the first screen then i hit navigator and it takes a bit loading then comes up with "error, cannot start the main navigation engine!...
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
The link below has the operating manuals and software available and contact numbers.
Thanks for using Fixya, please accept my solution.
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=43NT&subpr=&categ=
Jun 01, 2011 | Nextar 43NT GPS Receiver
What to do when error screen "cannot start the main navigation engine! please try again" is displayed
I had this same navigator and had nothing but problems with it , so I pitched it in the trash, In my opinion it was junk.
Nov 07, 2010 | Nextar Q4-04 Car GPS Receiver
Fatal application error
pplication adeona. oddysseyCore has performed an illegal operation and will be shut down. if the problem persists , contact the program vendor. program: adeona.odysseycore exception: 0xC0000005 address: OO1FOAEO
Aug 26, 2009 | Nextar X3 GPS Receiver
No results when navigation is pressed to operate
There is no map data or it has become corrupted get the maps reinstalled
Jul 27, 2009 | Nextar X3-03 Car GPS Receiver
GPS stuck up
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Jul 07, 2009 | Nextar X3-02 GPS Receiver
Nextar S3 Application error in Navigate
You need the contents of the \ResidentFlash directory. You'll need to rename the MobileNavigator folder and the four gpspara files (0,1,2 and 3) then load the new folder and files from a device that is working. You will then copy your old \ResidentFlash\MobileNavigator\UserData folder from your backup to the new folder to regain any favorites you might have created. You should then be good to go. I use ActiveSync to talk to the S3. I'm not sure how else you might attach to it.
I have the ResidentFlash files but I have no place to post them. The files zip to about 5.3 MB.
Feb 27, 2009 | Nextar S3 Car GPS Receiver
I have poblem with my gps
i have a nextar w3g, and this gps is running with windows CE, is possible the problem to be a virus or some othe errors you can find in every other windows sistems.
Aug 30, 2008 | Nextar X3B GPS Navigation System
Intellinav.exe application error
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Jan 06, 2008 | Nextar Q3 GPS Receiver
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
Nextar M3-02 GPS Receiver Logo
669 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
