Cell Phones Logo
S
Soud Kisome Posted on Apr 23, 2018
Reset buttons does not functioning. what the possible problem and the solution
AOC 24G2U all buttons only control the input since this week, can't access the settings menu and the screen will start to switch input by itself?
If the buttons on your AOC 24G2U monitor are no longer functioning as expected, and you can only control the input/source selection, it indicates a possible issue with the monitor's control panel or the firmware. Here are some steps you can try to troubleshoot the problem:
  1. Power Cycle: Turn off the monitor and unplug it from the power source. Wait for about 1-2 minutes, then plug it back in and power it on again. This can help reset the monitor's internal settings and may restore the functionality of the buttons.
  2. Button Combination Reset: Some monitors have a button combination or sequence that can reset the settings to their factory defaults. Consult the user manual for your AOC 24G2U monitor or visit the manufacturer's website to find the specific button combination for resetting the monitor's settings. Follow the instructions carefully to perform the reset.
  3. Firmware Update: Check if there is a firmware update available for your monitor model. Visit the AOC website or contact their customer support to inquire about firmware updates. Updating the monitor's firmware can sometimes resolve issues with the control panel and restore full functionality to the buttons.
  4. Physical Inspection: Inspect the buttons on the control panel for any signs of physical damage or debris. Sometimes, dirt or debris can interfere with the proper functioning of the buttons. Use a soft, lint-free cloth to gently clean the buttons and the surrounding area.
  5. Contact AOC Support: If the issue persists after attempting the above steps, it's recommended to contact AOC customer support for further assistance. They can provide specific troubleshooting steps or arrange for repair or replacement if necessary.
Please note that the steps provided are general guidelines and the exact steps or options may vary depending on your specific AOC 24G2U monitor model. Always refer to the user manual or contact the manufacturer's customer support for model-specific instructions.
2answers
Fujifilm av150 My playback picture button isn't working
If the playback picture button on your Fujifilm AV150 camera is not working, there are a few things you can try:
  1. Check the battery: Low battery power can cause some functions of the camera to stop working properly. Make sure that your battery is charged, and try replacing the battery with a new one to see if that resolves the issue.
  2. Check the camera settings: It's possible that the playback function has been disabled in the camera settings. Go to the camera's settings menu and look for an option related to playback or reviewing pictures. Make sure that this option is enabled.
  3. Clean the button and camera: Dust, dirt, or debris can sometimes get stuck under the buttons on your camera, causing them to become unresponsive. Try cleaning the button and the surrounding area of the camera with a soft, dry cloth.
  4. Reset the camera: Sometimes, resetting your camera to its default settings can fix issues like this. Refer to the user manual for instructions on how to perform a reset.
  5. Check for firmware updates: In some cases, a firmware update may be available that addresses issues with the camera's functionality. Check the Fujifilm website for firmware updates, and follow the instructions to install any available updates.
If none of these solutions work, it's possible that there is a hardware issue with the camera. In this case, you may need to take your camera to a professional repair service or contact Fujifilm customer support for assistance.
1helpful
2answers
I have a onkyo av receiver Tx-sr309 that is stuck on BD/DVD mode and no other keys/buttons on the receiver nor the remote functions. Not possible to do factory reset as well. Kindly help
‘I have a onkyo av receiver Tx-sr309 that is stuck on BD/DVD mode and no other keys/buttons on the receiver nor the remote functions. Not possible to do factory reset as well. Kindly help’ Of course, no reset is allowed due to single task MPU.
This is a very easy issue to fix and a common faulty situation found in onkyo AV-amp. If you want to know how to fix, just send an email to me if you want. It is up to you to do so and email will be deleted after ONE week. I won‘t tell you here due to buying faulty AV amps to repair and sell them out on web.
How can i do a hard reset on coolpix l27 ?
Turn on the camera and press the Menu button. Use the multi-function buttons to scroll to the tab with the symbol that looks like an ope-end wrench. Scroll to "Reset All" and press the OK button and confirm that you want to reset the camera.
Dont remember my gmail account
Tablets have a factory reset/wipe function that you can use when you don't have access to it because of forgotten password or for xy reasons. The process will vary from tablet to tablet and it will wipe all the data doing a factory reset, this method is only recommended when no access to the tablet functions are possible. For android tablets try this, shutdown the tablet, hold the volume up and down buttons at the same time and with your other hand press the power button, don't let go of the other two until you see a menu, using up and down buttons select the option that says factory reset and press the power button once to confirm selection. give a few minutes while the OS is being reset to factory defaults. For an Ipad try using Itunes to do a firmware restore.
We have a noma inside timer program and have no mamual for it and cannot seem to have it come on
Timer is not identified:
Look at following options:
Noma brand is old Intermatic brand that is sometimes/usually associated with Woods, but is also be used by various sellers to denote they are marketing a timer.
1) Add a comment and describe timer in detail, and/or post a photo of timer on Flicker and add a comment with link to photo.
2) Open following link to identify same-similar timer and download possible manual
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) If timer will not operate, last step troubleshoot is to reset timer.
Most plug-in timers have reset button. Press reset button and see if timer display is restored.
Some timers require additional button pushed along with reset button, some timers require 2 buttons pushed to reset timer.
Some timers have a batter that needs to be replaced. Replace battery and reset timer.
If functionality is not restored after reset, then check outlet for power. Test outlet with circuit analyzer.
If outlet is good and if functionality is not restored, then timer has gone bad.
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
http://waterheatertimer.org/ST01C-program.html
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
JVC KD-G801 - Buttons not perform correct function
disconnecting the main harness will reset the microprosessor it is possible that it just locked up and resetting the unit by unplugging it may help. or you might have a bad switch in the face of your unit
if unplugging your jvc doesn't help you can e-mail me at [email protected]
1helpful
3answers
SONY DSC-W100
it can be possible to select reset icon by selecting menu option.
it is not possible to take this type of pictures because at auto flash mode the subject can't be covered witin flash range .therefore picture may underexposed however the forground within flash range may correctly exposed.If we do all this at flash off mode the motion of subject will appear  as blurred due to slow shutter speed.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
