Question about Fedders AEQ07F2BG Air Conditioner
On the fedders aeq07f2bg is there a drainage tube or does it drain from the corners ?
    Champion:
  • 363 Answers
Most newer a/c units have a weep hole or drain port on the bottom of the unit, some have a place where you can hoopup a drain line.
Posted on Aug 01, 2009
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: is there a drainage tube or does it drain from
Probably out the corners. The unit needs a big old puddle of water so the slinger blade can help cool the condenser coils. If the unit is tilted towards the inside of the hoscienda then water will come inside and will be spitting out of the evaporator. That ain't too cool (pardon the pun). You would need to reposition the unit so that the water will flow towards the rear of it.
That way the agua will disperce outside. Do not drill a hole or run a wire into the unit as that could bust the sealed unit. Not good.
Nissan quest sunroof drain clogged
open your skylight and feel in the front corners for muck stuck infront of the drainage holes. Use a pipe cleaner or other wire to poke through the holes and the water should drain out. It is a little difficult to see the holes but just feel around.
Apr 18, 2013 | 2004 Nissan Quest
Rheem tankess RTGH model error code 29
The neutralizer has a plastic drainage tube going out of the case at the bottom left corner. You need to remove the valve on that tube to let the water drain out freely.
I had the same problem for my new Rheem.
Aug 07, 2012 | Rheem Water Heaters
What does the air exchanger do?
Pulls in some outside air as it runs to bring in fresh.
Sep 12, 2011 | Fedders AEQ07F2BG Air Conditioner
Leaking inside. Fedders A3X05F2A-J Unit is sloped away from house. Have sprayed coils. Doesn't seem to be drain hole at back of unit
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Fedders A3X05F2A Air Conditioner
Ice collecting above drainage tube. I removed the ice, the drainage tube was not clogged. A fridge repairman said problems like this were sometimes caused by warm air coming up the tube and suggested to...
The draining tube / tubing somewhere has a gooseneck similar like the one under your kitchen sink. That is to prevent air from coming up the tube. The area above the draining tube is supposed to be kept ice-free either by the closeness of the defrost heater or it has itself a heater built in.
May 08, 2011 | Danby D1707W Refrigerator
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
Is there a drainage tube or does it drain from the corners? on the fedders aeq07f2bg
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
How do i install my fedders aeq07f2bg ?
in a window with outside tilted slighty down to drain
Do i have to install my fedders aeq07f2bg on an angle to let the water drain out
It is a good idea to have the rear just slightly lower than the front edge to prevent water (condensate) from dripping inside.
However, most window a/c's use the heat from the unit along with the fan to dispel the water out the back and/or sides of the a/c outside the house.
If you do have the a/c tilted just back a bit, it should prevent any surprises and puddles on the floor, if you leave the a/c running when you're not home, etc.
Hope this helps and best regards!
Fedders AEQ07F2BG Air Conditioner Logo
90 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
