Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
SOURCE: Security Code Nokia 6030 Type RM-74
RM 74
IMEI NO 358378005209984
UNLOCK CODE???????????????????????
SOURCE: nokia 2630 security code unlock
please help me to unlock my nokia 2630,i forget the puk code of my unit.
SOURCE: nokia 6288
try this and will solve the problem :
Switch-off your phone.
1. Press and hold 3 keys; Green
dial key, * Star key, no. 3 key on keypad and then press the power
on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck .
rate if useful please !
http://songiaco.com/son-kim-loai/son-tre...http://sonmavang.com/son-ma-vang/son-kim...http://sonkinhcaocap.com/son-kinhhttp://decor247.com/son-dan-dung/son-tre...https://sondandung.comhttps://dodongtruongphat.comhttps://mavangcaocap.comhttp://songiada.cohttp://cuacongsatdep.comhttp://dichvusoncaocap.comhttp://sondandung.net
???? 4.67 ?? 5
10,000 ?????
???? 4.67 ?? 5
4,000 ?????
???? 4.33 ?? 5
2,000 ?????
???? 4.50 ?? 5
9,500 ?????
5,000 ?????
???? 5.00 ?? 5
5,000 ?????
???? 4.67 ?? 5
495,000 ????? 395,000 ?????
???? 4.65 ?? 5
185,000 ?????
???? 5.00 ?? 5
195,000 ?????
30,500 ????? 23,000 ?????
790,000 ?????
45,000 ?????
590,000 ????? 410,000 ?????
What is a code for wega led tv sir?
