Question about Refrigerators
Refrigerator was running and now it isnt
G e profile model TCS18PADBLBS - I just picked this used refrigerator from a friend and it was running fine at their house. The freezer was cooling quickly and the refrigerator taking a little longer. Now the entire thing has quit running. It was left open for putting the shelving in and then to put items in as it was cooling.
Any ideas?
    Problem Solver:
  • 10 Answers
I have heard that after moving a refrigerator, it should not be plugged in for twenty four to forty eight hours. not sure of the reason.
Posted on Aug 01, 2009
MY GE PROFILE MODEL PSS26LSRE SIDE BY SIDE FRIGE CRISPER IS FREEZING UP
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile PSS26NGS Side by Side...
I have a ge profile fridge model # PDS22SHRBRSS needing help
Yes, you have to cut the wiring as the instructions stated. Not all the models have to have wiring cut, so read carefully to see if yours is one that needs to have the wiring cut. If it is not, then you have another problem, and you will have to let us know what the origional problem was before you replaced the board. If your model requires cutting, you may have damaged the main board by not doing this. Unplug the refer and follow the instructions carefully and test to see if it works. Good luck, Appliance Specialists.
Feb 04, 2010 | GE Profile Stainless Bottom-Freezer...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
My refrigerator/freezer isnt getting cold enough
The problem usually isnt in the freon it usually is in the defrost system located in the freezer.I guess you have got this fixed by now and Im sorry for taking so long to get back to you but I havent used the computer in about four months because of family emerg. if you have any more problems let me know.
Sep 29, 2008 | Kenmore 53092 / 53094 Side by Side...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Jan 03, 2008 | Refrigerators
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
