Question about Totoku CCL250i Monitor
2 Toto Guinevere toilet levers stay up after flush - wastes water
I also am having trouble with our 2 Guinevere levers staying up. Plumber was of no help. Installed 4 other models of Toto toilets with push down type levers and they all work fine. Seems to be a problem with the Guinevere since it happens on both of mine and I see someone else with the same problem and no solution yet.
Often the chain or cord in the toilet tank has caught on something. Only lift the tank lid when water has stopped running. When replacing the tank cover, check if vertical water pipe has to sit under the lid just so to catch the vertical discharge, if so designed. Or perhaps the rubber stopper has deteriorated. Good luck
Posted on Aug 01, 2009
Five year old Toto toilet has developed a very slow flush in the past few weeks. Plumber has found no clog in line and water from hose flows freely with no back up. We have two other similar Toto toilets...
This can happen if there is a hole (physical damage) inside the trap. Instead of the weight of the water during a flush causing it to drain right down suddenly and completely, it draws in air and loses the momentum. There could be a hole or a crack, which may be hard to find without removing the unit.
Feb 19, 2011 | Toto Ultimate One-Piece Toilet MS854114
I have a Carlyle water saver toilet. The one that has two push buttons built into the toilet tank lid. It is a solid 1 piece toilet. My problem is every hour the toilet is flushing by itself. Had a...
Hello. Your lid has two buttons so you can do a half flush or a full flush. A water saving feature. Since the toilet is flushing by itself every hour or so, you must have a leaking flush valve. Replace the valve to solve that problem. Joe
Oct 12, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
The bowl is full of water and cannot be snaked by a plumber it will not flush. it is a neorest 600
When you say it does not flush; do you mean it flushes...the water just won't go down (won't empty the contents of the toilet bowl)?
Be more specific.
JZ...
Dec 09, 2009 | Toto MS990CGR-11 Augusta Decorative...
Toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Jul 09, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Flush handle stays in up position when flushing my Toto MS974224CF(G) Guinevere toilet. My other Toto, same model, works fine. I have tried changing the flush handle and changing the length of the chain...
Sorry, didn't read the whole thing. Moving parts do get sticky. Try cleaning, maybe with a soft wire brush if necessary, any of the turning parts involved. And a little WD-40 or migrating fine oil spray by any other name will do. Otherwise, a small bend introduced to one of the arms involved may help. It would be best if you could watch the operation, and if you can slow or speed the water coming in, that might change the performance. See if that helps.
Jul 02, 2009 | Totoku CCL250i Monitor
Toto seems to flush,but suction not working and waste not emtying
check the discharge hole, meaning you have to take down the toilet.
and make sure the water in the tank is at a proper high. you need the volume to create the wirlpool and push the waste.
May 20, 2009 | Toto MS853113S#11 UltraMax Round Toilet,...
Our toto toilet wont flush the water down. We plunged it to no avail, then we ran drain clearing baloons it wouldnt clear out. we keep removing the water with plastic pots. So we can try something else....
Sounds like something is either in the bowl stuck or down in the waste line. I would probably pull the toilet and pour water down the waste line to see if it backs up or set the toilet up on something and pour water into the bowl to see if it comes out. At least it will help to find out where the problem is. Have you lost anything recently that might have fell in the toilet. Did something come off of the plunger and get stuck in the bowl?
Feb 19, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
Toto Drake ADA: Usual rush of water on flushing doesn't happen
Problem solved.  Reason was a totally blocked waste line that resulted in toilet malfunction.  Toilet functions normally now with removal of blockage.
Dec 27, 2008 | Toto Drake ADA Compliant Toilet with...
Have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Dec 15, 2008 | American Standard Home
Totoku CCL250i Monitor Logo
123 people viewed this question
Top Totoku Computers & Internet Experts
David Payne
David Payne
Are you a Totoku Computer and Internet Expert? Answer questions, earn points and help others
