SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
SOURCE: hi i have a simpson
We had the same problem. Electrolux repairman came last week and replaced the lid switch parts with a new designed part. Told me the original part was subject to recall because of a problem with the design, was getting wet and stopping the maching operating correctly, and causing shocks. Ring Electrolux, should be covered under the two year warranty (but because the fault was there when the machine was bought, shouldn't matter even if warranty period had expired)
SOURCE: I have a 5.5kg Simpson
yes the safty door latch switch is eather loose or going bad. somewhere on your door there is a small sensor or switch that tells the washer the door is closed and its ok to spin, these washers put out alot of force when spinning and thats why the sensor is there it would be dangerous without them. when the washer goes in spin cycle there is more vibration than any other cycle. and thats whats making the sensor or switch wiggle and its getting an intermedate signal. it probily needs replaced these can commonly go bad due to wear buy slamming the door on the washer.. i hope this helps
SOURCE: Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
