Question about Whirlpool GU2400XTP Built-in Dishwasher
Maytag dishwasher not draining fully
Maytag dishwasher, model MDB5600AWW. The dishwasher is not emptying fully, leaving dirty water in the bottom at the end of a cycle.If I start and immediately cancel a new cycle, triggering a drain cycle, I can hear the pump click on and the water is mostly removed. Sometimes it seems to take two cancels to really get rid of all the water. The dirty water is never being fully pumped out before the rinse, so my dishes aren't rinsing clean. I checked the drain hose and found no blockage, and I dismantled the interior as far as the filter and chopper blade and found no clogs. Any idea of what the problem might be? Thanks!
  • 3 Answers
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
Maytag 100 series - how do I clean the filter? There is black gunk coming out
Try running a cycle with citric acid from the canning section and the grocery store on the hottest cycle
Jan 02, 2016 | Maytag Dishwashers
I need a manual for the Maytag MDB5600 dishwasher
Hi there
Very irritating taking dirty dishesout of the machine. You havelooked at the bottom,emptied and cleaned the svive. And listened to sound when emptying, is it the right sound?
Go online and look for MANUALSONLINE.COM. I WOULD NOT BE SURPRISED IF YOU FOUND your Maytag there.
good luck
Kolbrun
Mar 12, 2012 | Dishwashers
Maytag dishwasher model DWU9906BAX, 15 years old, in the past 6 months we have been finding dirty water in the bottom between uses. We have made sure the 'drain' cycle emptys the bottom after...
This is truly a drain pump fault as it fails to pump out the dirt and water. In a period of time the drain can get choked and so it will not drain out efficiently. so it is best to remove the pump and clean up the drain section which must solve this issue. keep the washer tilted to drain properly.
When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 15, 2011 | Maytag 24 in. DWU9902 Built-in Dishwasher
My dishwasher is leaving residue on dishes and not draining fully at the end of a cycle. There is still water at the bottom when complete
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Jul 15, 2011 | Maytag Dishwasher
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
My Kenmore Ultra Wash Dishwasher Model#665.13842K600 doesn't fully drain a the end of the cycle. There is always dirty water left in the bottom of the unit.
Dishwasher Problems - Water will not drain out
heatman101
Oct 02, 2010 | Dishwashers
Our dishwasher will not fully empty and does not clear all debris leaving pots still dirty. i have cleaned filter. sean
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Sep 24, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Maytag eq plus dishwasher- how to disassemble bottom spray arm?
its probably leaving water in it and is clogged in the elecric pum or drain hose. somethins the pump has a rubber flap that will become lodged in the outlet port. this will cause dirty water to be left in the machine because of a slow drain. start by looking at the volume of water coming into garbage disposal where drain hose hooks up.
Aug 01, 2010 | Maytag Dishwashers
Dishwasher drain pump flapper (inlet side)
My Quiet Series does the same thing and I wondered if the orange flapper has gone bad and lets the dirty water drain back from the hose sloping up to the garbage disposal. Did you get an answer to this question? The dishwasher seemed to work fine and then it suddenly started leaving food particles on the glasses.
Jan 15, 2010 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,481 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
