Question about ASUS A8N-SLI Deluxe Motherboard
Usb problems After attempting to install KB941600 and KB941649 (vista) my usb mouse (and game controllers) have refused to work. However, the usb flash drive still works, but only in 2 of the 4 ports. This problem persists even after I have successfully installed the aforementioned updates. System restore has also failed to fix this. The PS/2 ports still work. This is very confusing to me, please help.
  • Anonymous Apr 28, 2008
    I have wireless mouse which stopped working after 4-14-08 vista update. mouse is plug & play (no driver) . Have tried several suggestions. only one that worked was tuning off updates & restoring to a compatible configuration. Vista has me so frustrated! Can I fix it right?
  • John Powell Jul 13, 2008
    I have 2 ASUS A8N Deluxe SLI mother boards, 1 working fine in my system the other in my sons sytem, I have installed all USB drivers which pick up his USB Mouse fine but all other USB Items wont work at all, Please could you HELP!
    Thanks
    John
    President:
  • 2,351 Answers
Though this motherboard is not fully VISTA capable, you may still be able to try it out using either VISTA built in drivers or their native Windows XP device drivers.
Please kindly refer to the page below for a list of "VISTA installable" non-VISTA compatible motherboard:
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=897&SLanguage=en-us
Posted on Jan 03, 2008
Mt usb mouse is suddenly no longer recognised by
Hi , just make sure , that you are installing the correct drivers, that it is 64 bit and not 32 you are installing..
That does cause a few problems.
Thanks
Dec 29, 2009 | Warrior 797146022002
I just bought a new mouse for my laptop. It is a Targus Kaleidoscope Optical Mouse. For my HP Pavilion dv2700, I plugged it in and it will not work,it did install itself several times.Everytime I plugged...
First thing you need to do is to know that the USB ports of your laptop is really working. Insert another usb devices or storage such a flash disk. If the flash disk being inserted is not recognized by the system then the usb port you had inserted is malfunctioning or it is defective. But if the other usb devices like the flash disk is working then your new bought mouse is defective. Try to plug the usb mouse to the other ports available in your laptop.
Oct 29, 2009 | Targus Kaleidoscope Optical Retractable...
My laptop dose not recognice my mouce...... it says device unknown.......... the mouse works on any other system......... i have a 64 bit vista .... what do i do
Check whether you are having the USB controllers installed correctly or not. To check this navigate to device manager and in that check for the USB controllers , then right click the USB controllers and then uninstall them , then goto "Action" Tab and perform "Scan for Hardware Changes" then the USB controllers are installed properly.
Oct 21, 2009 | KEIO PS2 Optical Scroll Mouse
My S.O. Vista x32 doesn't recognize my mouse optical labtec 800
you can check your usb driver
it's work or not
you can go to control panel after that system device and hardware
and check proper install or not
Sep 20, 2009 | Labtec 800 Mouse
Frozen cursor on new emachine laptop
Before you plan to return make sure you have done some or all of this things first:
1. Did you reboot after you installed the Enterprise 2007 ?
2. Did you make sure that if its a USB mouse that it is securely connected to the USB port ?
3. Were you able to move your mouse without any problem at all before the software installation ?
4. Have you had this problem before the installation of Enterprise 2007 ?
5. Have you done all your software and windows updates ?
6. Will the mouse work when booting into Safe Mode ( pressing F8 during re-boot before Windows Vista loads) If it does then your softwares need to be updated.
7. Did you check you device manager to see that theres no yellow exclamation anywhere in the Mice and othert pointing devices or under the USB controller section?
8. Is there a legacy USB port to be activated on your computer BIOS ?
If the installation caused your mouse to be frozen then try and uninstall the Enterprise 2007 by using your keyboard and tab to the programs uninstall.
If your mouse still doesn't move after doing all of the above things
then try another new USB mouse. Sometimes you may have to wait for several seconds (even up to a minute for new usb mouse detection) before the USB mouse cursor will move. If the second new USB mouse still wont work then return it to where you bought it as it could be faulty usb connector
Dec 28, 2008 | Computers & Internet
Mouse drifts when gaming
I had a Playstation 2 - USB adapter plugged into another USB port with out the PS2 Controller plugged in.
This caused the mouse drift
Feb 28, 2008 | A4tech X-710 (X7102)
Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Feb 25, 2008 | Targus AMW15US
Belkin Optical Mouse
in control panel device manager, select the device and attempt to re-install the driver from a list of compatible drivers - select HID Compatible Mouse as opposed to USB Browser Mouse
Oct 31, 2007 | Belkin F8E836-USB-MOB Mouse
Installation
First, I'm going to assume this controller is usb and not wireless, blue-tooth, or gameport. Second, if you have a usb mouse or keyboard and it works fine, then its going to be that you need to find vista drivers for your device and install the drivers before plugging it in. If you have another usb device, try plugging it into the usb port and if it doesnt work either your computer is faulty or you need to update it. Vista is rather fickle when it comes to drivers and what not. Instead of windows coming out with the drivers, they let other people come out with them then they endorse those drivers. Try going to logitechs site, they are usually extremely helpful and easy to navigate. You can probably find drivers for your device easily. If you need any more help, let me know, I'll find you a few other solutions.
Sep 12, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
ASUS A8N-SLI Deluxe Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
