Bowflex
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS”
or “err OS” is displayed
Calibration Re-calibrate machine using Owner’s Manual
calibration procedure.
Speed sensor 1. Cycle power off and on.
2. Put the machine in calibration mode (see Calibration
procedure in Owner’s Manual) but do not
start the calibration routine.
3. Remove right rear plastic cover to view LED
diagnostics on control board.
Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board.
LED may be lit or unlit.
5. Manually advance the treadle with your foot,
and check if LED D is blinking.
6. If LED D is not blinking, then the speed sensor
is not supplying a signal. Check that the speed
sensor wire is plugged into the motor controller
board, to the connection labeled “P1”. Check
connection of speed sensor to jumper wire.
Check speed sensor adjustment (use business
card to set gap between sensor and pulley). If
LED D still does not flash replace sensor.
I/O cables If LED D is flashing when the belts are turning
but err LS or OS persists check connections and
for signs of visible damage to any of the three I/O
cables. If no damage, check continuity using a
multi-meter. If a multi-meter is not available contact
customer service for replacement cables
and further assistance.
Mike
SOURCE: My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
SOURCE: I have bowflex treadclimber tc5000,
This is a common issue caused by a frequent assembly problem, made worse by the tools sent along with the TC for
assembly. To fix it, you need the following:
1. A GOOD 5/8" wrench (not the piece of junk that came with the TC).
2. A Phillips screwdriver at least 3" long.
3. Two books at least 1" thick.
4. One book about 3/8": thick, or two magazines
5. A vacuum cleaner with a hose.
6. The Treadclimber Manual. If you don't have it, get it online at the company's web-site.
Lock the treadles (see manual) such that the TC is just a treadmill.
Turn off the TC, unplug it, and remove the power cord.
Leaning the TC first left, then right, put the 1" books about 2/3 of the way towards the back under each side. This will left the rear of the machine slightly off the ground, making the following steps much easier.
Now use the Phillips screwdriver to remove three screws on each of the two rear-most plastic covers at the base of the machine. Remove the covers. Put the screws in the covers so you don't lose them. Note that the top screw is recessed deeply into a hole in the cover!
Removing the side covers has exposed 4 more Phillips screws that hold the back plastic cover in place. Remove them, and the cover will slip off (thanks to those two big books).
Everything is dusty dirty. Use the vacuum cleaner to clean it up. You'll thank me later when you don't sneeze your brains out.
Now, behind where the back plastic cover was, and across the back of the machine, are four big bolt-heads. These are the bolts that hold the tread assembly to the base of the machine. They're probably loose. If they're not loose already, use that wrench to loosen them a bit. Either way, things are out of whack.
Go around to the front of the machine. Use the small book or the magazines to wedge the right treadle away from the upright such that the treadles are evenly spaced between the two. Don't over-do it and reverse the problem! (This is a lot easier than yelling at your spouse or significant other to "hold it, hold it" while you complete the next step.) What you want is the two treadles nicely spaced between the front uprights. Trust me, the right treadle will hold that spacer.
Go back to the rear of the machine. Using the 5/8" wrench, tighten the four bolds VERY tight. Use some muscle. The fact that they were loose was the cause of the issue.
Now go to the front. Pull out the book/magazines that you were using as a spacer between the right treadle and the upright. Do the treadles look like they're now evenly spaced between the uprights? If so, pat yourself on the back. If not, then loosen the bolts and try again, adjusting the thickness of the front "spacer" as needed.
Put the rear cover back on. Don't over-do the tightness of the screws on this (or the other) cover(s)!
Put the left and right covers back on. Take care with these, they're a bit delicate, especially the top screws. If the little rubber posts fall out of the top screws, finesse them back in.
Don't forget to re-calibrate the machine (per that manual) after you finish.
You'll now discover in most cases that a lot of issues with uneven action are now cured. Any rub marks on the right upright can be removed with the same silicone spray that is recommended for the belts.
Enjoy.
SOURCE: one treadle is rubbung on the upright
The rear bolts are loose. I had the same problem and found the four 3/8" bolts loose. You need to take the rear side covers off first then the rear cover to get to the bolts.
SOURCE: Bowflex TC5000 L5 Belt will not move antmore.
Dear Sir:
Hello , I hope everything is fine with your family.
Thank you by your request, and I will help you inmediately.
You have a Mechanical problem, please do the following:
Please do this with carefully!
The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset.
Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it. A drive belt is usually $29.99 or less while many parts you can damage by over tightening can be more than $300.
Additionally, too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure. It is better to having the belt a little too tight rather than too loose due to the possibility of injury if the belt slips.
Motor Belt Adjustment- Icon Units
DO NOT REMOVE ANY OF THE MOUNTING BOLTS TO THE MOTOR. SOME MODELS WILL REQUIRE 2 9/16" WRENCHES AND MAY REQUIRE TWO PEOPLE TO ACCOMPLISH THE REPAIRS
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stallthe belt to make it slip.
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5.
Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5.
Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position.
Thank you in advance, sincerely. God bless you.
If you need further help, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
