SOURCE: ThinTwin cabinet access
a little awkward atfirst but shlould be a problem. remove the angular panel along the rear of hte washer top youll see two brass clips an inch in on both sides, with a screwdrier "pop" these clips off, and if i remember correctly there are (2) 5/16 screws directly behind them (sorta on the frame of unit just below the rear lip of the top) the main top then will slide toawrd you and rigth off. a screw secures the front panel on both sides adn it too lifts up and off. acess to pump is right there. reverse order nad your good to go.hte brass clips will SNAP right back in place when lined up correctly
SOURCE: no cold water coming into machine (handyman thinks
Check the water shut off valves behind your washer. Make sure they are full open (turn counter-clockwise).
Turn the shut off valve off (full clockwise). Disconnect the hose and try running it into a bucket from the valve to make sure you have good water flow.
Check the hose from the shut off valve and make sure it's not kinked stopping water flow.
Turn shut off valve off completely...disconnect hose and look at the end that attaches to the washer. Is the metal screen clogged? Look at the water inlet on the washer where hose attaches and make sure there are no obstructions.
Testimonial: "Thank you so much -- will try all you suggested and hope for the best!! (glad to have an option before a repair person)"
