Question about Kenmore 700 6972 Dryer
Is not heating
When we turn the dryer on now, it is not drying with heat,. The last load dried very hot. What do you think is wrong?
    Problem Solver:
  • 10 Answers
I think when this happened to my sister it was the heating coil. her dryer caught on fire. don't run it unattended.
Posted on Aug 01, 2009
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
It takes several auto cycles on regular heat to dry a load of laundry when I think it should only take one. What's wrong?
first, check your exhaust, you have to make sure there is no buildup at all inside it. this is the most common problem to cause this. if lint gets backed up, there is a sensor that shuts down the heating element after only a few seconds. hope this helps
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer does not dry
any number of things actually, lets start with the basics, does it start at all just not dry???with a meter you can troubleshoot most problems right behind unit taking off back panel and checking the thermostats for continuity, the heater can also be checked right there , any one not having good continuity needs to replaced, perhaps after 3 loads it got too hot and overheated a thermo or the heating coil went bad
Mar 17, 2008 | Kenmore 63102 Electric Dryer
Kenmore 700 6972 Dryer Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
