Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
My gfss6kkxass doesn't make ice - General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
  • 34 Answers
Check first the setting of thermostat if on proper setting in cooling if nothing happen there is a problem on charging or lack of freon or under charge.
Posted on Aug 01, 2009
Ge gfss6kkxass front panel doesn't work
This repair is too complicated for the homeowner..
About the only this you can try is to unplug the power cord
wait 3-5 minutes and restore power. If no results I would
go to the main motherboard then to the display board..
These are R/R (Remove & Replace) parts and can be expensive
to repair..
Jul 27, 2014 | GE Refrigerators
Gfss6kkxass
It could be fan or door switch that will stop fan motor
Jan 16, 2014 | Refrigerators
Kenmore model 580.54351800 ices up quickly, doesn't defrost, and as a result doesn't dehumidify. Bad thermistor?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 12, 2011 | Kenmore 54701 Dehumidifier
Icemaker doesn't work....It doesn't fill with water???
Check your water supply ,make sure valves are open. make sure ice maker arm is in down position
Jun 22, 2011 | KitchenAid Architect 25.3 Cu. Ft....
I have water under the vegetable tray. I believe the drain valve is probably clogged. How can I fix this? My GE model bottom freezer model number is GFSS6KKXASS.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Apr 25, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Doesn bring water to ice maker
If you have water at the door, the most likely problem is that the metal bar that shuts the ice maker off has been moved to the off position. Check to see if the metal bar is in the up or down position. If it is up, move it down and vice versa and give it an hour to see if it begins making ice again.
May 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Turn on fridge
Press the Ice Off button and the Freezer button together for thirty seconds. Set your temps at 36 for refrigerator and 0 for freezer.
if that doesn't work, press the freezer button and the energy saver button for thirty seconds and do the same thing.
Jan 20, 2009 | General Electric GFSS6KKXSS Stainless...
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
607 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
