SOURCE: Frozen Water in Pan behind freezer drawer.
yes you will have to remove the freezer door and go through the front of the unit. the door itself is the easy part to get off, it lifts off the rails, you may have to remove a screw a few inches back fromm the freezer door on both freezer rails(phillips head screw, ). empty the freezer pullout before trying to remove. after that the the pull out upper shelf comes and thenyou can remove the horizontal rails , the ice maker drops down and then the back wall can be removed
SOURCE: Removing the refrigerator drawers from the Electrolux side-by-side refrigerator
Got it. My mother got one of these fridges and was frustrated with the drawers not sliding off to clean. It is designed to dissamble the complete drawer assembly. Start by removing the glass from the top of the chill zone drawer frame. Next grasp the white piece of plastic that the chill zone is written on and pull up. There are 4 pegs which affix the drawer assembly to the fridge. The front two pegs will pop out and then the rear will easily pull. The top drawer assembly must be removed before the bottom two drawer assemblies can be removed.
I also noticed the plastic pieces and tried to pinch them but I couldn't get them to budge. Once I saw the 4 pegs, it made sense.
SOURCE: f2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
SOURCE: how to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
SOURCE: I have a Diktad changing
Yes, go to hardwaretree.com or rufkahrs.com. The Double Acting Mini Slides DSP-8817/373 should work. Even though I only had one drawer to repair I bought three pairs in anticipation of further repairs.
How do you remove the dawers?
