Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
How do you clean the orfices of spider webs?
We have a LoNox 2100 Pool heater. I have had to call a repair man three times (once a year) to clean the spider webs out from the orfices. The last guy got in from the bottom side and used a long wire but now I don't know how he got to that spot. Our heater starts up but only heats to about 80-85 and then stops. I have been told that the spider webs blocks the gas. HELP!!!
    Problem Solver:
  • 9 Answers
You have to remove the burner assembly to properly clean the unit. remove the front panel there are 2 screws on the burner tray remove these and disconect the small pilot supply tube and slide the tray out to clean. use a wire brush lightly and an air compressor to cleat out the burners and the orfice.
Posted on Aug 01, 2009
Raypax 2100 pool heater will not stay lit?
dirty or bad flame sensor if wired 120 volt try reversing black and white wire
Sep 01, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 pool heater " PRS " diagnostic reading What does it mean and how do i correct it
This is low pressure. Start by checking your baskets for clean then be sure to clean the filter. Then make sure the by-pass valve is closed and lastly if your pump basket is cracked or broken check to be sure nothing is clogging your impeller.
Sep 19, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pilot lite will not stay lit, have a full tank of propane
YOU WILL HAVE TO TAKE THE TUBE FROM THE CONTROLLER TO THE PILOT TIP APART AND CLEAN OUT THE ORFICE AS THE SPIDERS MAKE NESTS IN THEM.
Nov 12, 2009 | Hayward H Series Pool & Spa Heater 400k...
I have a Raypac 2100 digital pool heater and it's reading PRS. Is there someone out there that can tell me where this pressure switch is? According to the guide, PRS means "pressure switch open". If I...
On the side of the heater where the pipes are connected; under the top cover. It is a round disk threaded into the header. It is likely that your filter needs a good cleaning if your heater has always worked reliably in the past. If you have a cartridge filter, it may be time for a new element if you can no longer get it clean enough to get the heater to work.
Sep 26, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
398 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
