Monitor very dim (unreadable) half of the times when laptop turned on.
  • maddmike71 May 11, 2010
    on battery or ac power? it might be your power settings, look for the battery icon down by the clock, right click it and edit the brightness in the power options.
  • 34 Answers
There is a problem on back light inverter or open inductor coil for supply of inverter transformer.i have encountered already for that problem.
Posted on Aug 01, 2009
Half of the monitor screen went dim
Faulty screen? Try an external monitor to prove it.
Apr 08, 2015 | HP ProBook 6440b Notebook
COMPAQ FP7317 IS VERY DIM ALL OF THE TIME
If the display is dim like on half of the screen or any kind of color variation, this could mean that your monitors CCFL lamps are going bad, more so than the display High voltage inverter, unless you can web search on how to replace the CCFL lamps for your monitor, it may be time for a new one..
Oct 25, 2012 | Dell E173FP 17" LCD Monitor
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
In your situation, you have the possibility of several different problems.
1. Your "Screen Inverter" is failing.
2. Your screen "LCD Panel" is failing
3. The "Video Controller Chip" soldered permanently to your motherboard is failing.
The first step in troubleshooting these problems would be to take your laptop to a friend's house who is using a desktop computer with a separate external monitor. Hook your laptop up to the external monitor and see if it displays normally on that monitor. If it does, you merely need to replace both the Screen Inverter and LCD Panel of your laptop and you'll be fine.
If, however, your laptop will not display on an exterior monitor, it means that your video controller on your motherboard has failed and you'll have to either get a new motherboard installed or consider replacing your laptop.
I'll be rooting for # 1 or 2.
Kind Regards,
Selk
Apr 29, 2011 | Sony VAIO Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Lower half of monitor goes dim
Replace the backlight in this unit will bring you back in business.
Thanks please rate.
Aug 19, 2009 | Star Logic 17" LCD Monitor
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Monitor dims
Your monitor in hardware problem front panel keys short in side.change menu switch on boar.or command section problem.check ic or componets relate it.
Mar 03, 2008 | HP mx705 17" CRT Monitor
Half a monitor
This could be a backlight problem- Dont know about a fix though
I guess some one may repair them[new tube[s]]
I guess what ever the labour plus parts will be well on the way to a new one.
How old is it by the way - any warranty left?
Jan 26, 2008 | Hyundai L91A 19" LCD Monitor
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
