My satellite remote will not turn off closed caption and regular remote has never worked. I'm not sure how it got turned on
SOURCE: rca system link 8av remote How do I turn off closed caption??
CC is usually turned off by selecting an inactive choice,i.e.
If CC1 is on, then try CC2......
Further info ? Please provide Model # of TV.......................T.
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there. Worked for us - got the idea from another fixya post.
SOURCE: closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
SOURCE: how to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
SOURCE: Mitsubishi CS- 27303 closed caption won't turn off
the closed caption is not in the menu, it is in the video adjustments color,bright,sharp,ect. get to those adjustments and scroll until you see C.C. turn it off. i had the same problem but my whole screen was a black box,bought a new tv and everything. just figured it out today
Hi Linda Ferguson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Can you identify the model or the service you are using? Do you have a manual? Do you have a trusted friend or relative (perhaps a teenager?) who could help you with this as FIXYA has thousands of unanswered questions and yours has insufficient information for a quick and easy answer to be given.
