Question about Garden
I dont know how to thread my edger properly. everytime I do, the threat cuts off and wont rethread automatically.
  • 154 Answers
You need to wrap a certain direction
Posted on Aug 01, 2009
I've rethreaded my 634d overlocker, and now it wont sew properly, its bunching up the threading behind the needle?please can someone help
Most often, the problem exists in the threading process. Try removing all the threads from the machine and rethread from beginning to end in the order specified. Any deviation with one of the threads may cause the machine to not stitch properly.
Nov 16, 2017 | Sewing Machines
Won't catch the bobbin thread everytime. skips. I have retreaded everything several times, reajusted tension, and even the presser foot tension.
Install a brand new needle.
Check the upper tension: Remove the thread. RAISE the presser foot and rethread from the beginning. This ensures the thread is seated properly in the tension disk. Make sure the bobbin case is threaded properly.
If still missing the bobbin thread, it probably has a needle/hook timing issue.
Feb 10, 2016 | Sewing Machines
Bobbin threat loose
Make sure you have threaded the machine properly--which usually involves removing the thread and rethread from the beginning. Make sure to RAISE the presser foot before threading the upper thread. Check that the bobbin is loaded in the bobbin case and it is threaded properly.
sewing machine loose bobbin thread Google Search
Jan 26, 2016 | Sewing Machines
How do you work a huskylock 430 serger
Here's an owner's manual:
User Guide
Usually, if the machine breaks thread, it is because it is threaded incorrectly, the tension is too tight, or there could be a bad needle. Make sure you are using the correct needle and inserting it properly.
Check to make sure the thread coming from the spool is not wrapped around something that it shouldn't, ie the spool pin or the thread tree.
Unthread everything, RAISE the presser foot, then rethread from the very beginning making sure the threads seat properly in the tension disks.
Thread each thread in order as instructed (usually the upper looper first and the lower looper second with the tail draped over the top of the first looper). Pull at least 6 inches of thread tail of all three threads and lay them all in a straight line under the presser foot extending toward the back of the machine.
BE SURE to check your threading sequence against the instruction manual diagram since missing one thread guide will cause problems.
Set all the tension dials to the midway point to test your stitching. HINT: it helps to thread with 3 different colors so you can determine which threads are presenting a problem.
When a thread breaks, it is best to rethread everything from the beginning. Sergers are very finicky machines and even if you try to rethread only the broken thread, they will generally refuse to work.
Dec 12, 2015 | Sewing Machines
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
Bernina 2500DCET serger keeps breaking the centre needle thread for no apparent reason .Already had machine serviced,new needle plate didn't solve anything either. Any ideas
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Mar 01, 2009 | Bernina 2500DCET
Don't know how to rethread the line
Breaking off is a normal process. Set the centre of your line in the spool and wind the two strands in to the Spool, thread and re assemble. C
May 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
